Sump pump questions
Old Nov 30, 2003 | 08:36 PM
BigMattXXL's Avatar
BigMattXXL
Unhappy Sump pump questions
We've got a septic/well system in my house, and we've got 2 sump pumps in two small wells - one for the ground water (or to keep the basement from flooding) and one for the toilets/showers/sinks waste water.
At any rate, The pump for the waste water is an interesting setup - there is a "piggyback" plug; it plugs into the wall, and then has an outlet on it, to which we plug in the actual pump plug. Now when I plug in the pump directly, without sticking it on the piggyback, it just runs and runs until I unplug it. When I put it on the piggyback, it's real spotty -sometimes it doesn't pump, sometimes it works fine.
I'm guessing that the piggyback plug leads to some kind of float mechanism which interrupts the current from the house to the pump. I'm also guessing that the float mechanism is faulty.
I haven't opened it up yet, but I wanted to see if you guys thought I was on the right path with this. I've never dealt with this kind of thing - I'm learning as I go.
Thanks in advance!
XXL
Old Nov 30, 2003 | 08:40 PM
Andysutt's Avatar
Andysutt
Sounda bout right, but don't quote me on it.
I'd call around and ask. Or I can ask my dad, as I think he has had some experience with this situation
Old Nov 30, 2003 | 11:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
The "piggyback" plug does indeed go to a float switch. The most common source of problems in a setup like yours is debris in the well causing the float to hang up. If the float is free and it is still not working replacement switches can be obtained from hardware stores.
Old Dec 1, 2003 | 05:28 AM
BigMattXXL's Avatar
BigMattXXL
Thanks Eric - let me ask you though - is that well full of poop and whatnot? It's covered by a wooden lid. I don't really want to be elbow deep in something I flushed last week
XXL
Old Dec 1, 2003 | 07:58 AM
nymo's Avatar
nymo
You don't have much choice. :eek There should be a rope to pull everything up. Get the garden hose or a pail of water to rinse things off. Get some old gloves you can discard and wear some old clothes.
Sometimes the floats get a pinhole and water seeps inside them. Then they can't float enough to trip the mercury switch inside. That's what happened to my last one.
Old Dec 1, 2003 | 09:20 AM
Nutter's Avatar
Nutter
I love to save a buck and do most things around the house myself. But I must say, a poopy problem of that magnitude would force me to hire outside help. Matt you have to draw a line somewhere on self home repair, doesn't this look like a great place to start.
Just think you have to pull the offensive poopy pump out, then diagnose the problem, after showering "you will need a shower after going in up to the elbows" run to the hardware store hoping they have what you need, all while the poopy pump sits on the floor stinking up the basement . Then it's back to the poopy pump (when and if you find the parts) and hopefully you've diagnosed it correctly and manage to repair it. Just think of not having to worry about it and having a poop pro fix it for ya.
Why does your mouth water just before you throw up ?
Old Dec 1, 2003 | 04:14 PM
BigMattXXL's Avatar
BigMattXXL
Thanks for the help guys - my mom ended up calling the plumber this morning while I was at my job training. Apparently the whole thing was getting ready to go - it all fell apart when he brought it out of the turdpool.
I'm not gonna complain...when I flush something, I don't expect to see it again
XXL
Old Dec 1, 2003 | 04:39 PM
maa139's Avatar
maa139
You may want to look at a battery back up for the system. A few years ago durring a hurricane, we lost power for 26 hours. My wife and I spent about 13 hours bailing water out of the sump into the shop vac to be dumped outside becuase no power=no sump pump. I haven't needed the battery backup yet, but I also haven't had to worry about losing power in the middle of a big rain storm either....
Old Dec 1, 2003 | 07:28 PM
wrh's Avatar
wrh
Hey BigMatt, I've never heard of a sump pump to move wastewater. Is that a system that moves sewage up from your basement to your inlet pipe for your septic tank?
tseekins
Jun 28, 2010 08:56 PM
ncinirator
Dec 29, 2009 10:13 PM
TN-W124 Diesel
May 18, 2005 10:46 PM
southpaw
Apr 13, 2005 08:15 AM
13MWZ
May 20, 2004 02:47 PM
