1966 - 1977 Early Broncos
headers gaskets
Old Nov 30, 2003 | 07:57 PM
ROKRAWL's Avatar
ROKRAWL
headers gaskets
do the gaskets for the headers go metal side to the block or cardboard side to the block? also, is any type of sealant needed?
Old Dec 3, 2003 | 03:21 AM
DeenHylton's Avatar
DeenHylton
I'd say metal side to the header flange, but the best way of telling is to place the gasket on the head and see which way lines up with the exhaust ports the best. The header will always be the hotest surface since it's not water-cooled and the head is.
You do not need to use any sealer on a header gasket...but you do need to occasionaly re-tighten the header bolts or you'll burn through the gasket.
Deen
