What year and model?
8 cylinder also feels locked up. Unless the motor is something unusual I’m thinking that locked up probably from rust it also has little or no value? heads are stamped 59A-B hard to read but easy to read on other side. looks like the motor may have mixed parts. The plug wires are grouped is sets of 4 connected to two different caps.
A couple dash components look like they might be salvageable.
On the V8, There are two caps,.one for each side of the distributor.
I did find f-6 emblems on the green truck behind it. It’s a ‘48 and will post about it later on the ’48 to ’56 board
I also removed this electric pump from the driver’s side frame under the hood. You can see it a photo I posted earlier. There is a stock fuel pump on the top rear of the motor. So what it this electric pump for? The steel part and transformer are toast but the zinc is in good shape. The truck has a 2 speed rear end wondering if it’s a transmission or rear end fluid pump.
