Tires for towing
Old Oct 14, 2024 | 11:13 AM
6.2caribou's Avatar
6.2caribou
Originally Posted by Hmcfly626
ok what that?
https://www.continental-tires.com/pr...0the%20carcass.
Old Oct 14, 2024 | 11:54 AM
khollister's Avatar
khollister
Michelin Defender LTX Platinum - 70,000 mile warranty.
Old Oct 14, 2024 | 05:00 PM
Hmcfly626's Avatar
Hmcfly626
Originally Posted by 99powerstrokedF250
I'll echo something from above: What pressures are you trying to run your tires at? Too low and it won't feel planted at all, it'll wander a LOT. Might want to push them up closer to the max cold pressure and see what happens before you buy another set of tires.
That said, most everybody above has given good options.
Michelin LTX: GREAT tire for towing on-road and gravel. If you're going anywhere that isn't hard-compacted, be ready to use 4WD or get stuck (my experience anyway).
Continental HT: Another good tire for towing, no experience with them off-road though.
General Grabber HTS: Had a version of these on an SUV, good stable tire. Seemed to do okay towing.
I would suggest, if an AT tire is what you're still after, look at the General Grabber ATx's. Good tire, pretty stable even when towing, and decent life too.
i don't know what pressure they are at they take care of that when I get my oil changed I
Old Oct 14, 2024 | 05:08 PM
khollister's Avatar
khollister
Roger that - any time I get on wet grass, it's 4x4 time
Old Oct 17, 2024 | 09:20 AM
Moho81's Avatar
Moho81
If your always on road the Michelin Defender's are nice for towing but from personal experience as soon as you are on anything other than pavement they are bad towing or not towing.
Old Oct 17, 2024 | 09:24 AM
Hmcfly626's Avatar
Hmcfly626
ok but these tire are a year old I have had this trouble ever since I got them i just really got tired of them this trip
Old Oct 17, 2024 | 10:26 AM
BDWSD22's Avatar
BDWSD22
Oh my goodness, YOU should monitor and be aware of your tire pressures. Your truck knows and so should you. If your truck does not have the info available on your dash, then invest in a guage for a buck or two. If the oil change place follows the placard on your door jam, then that is what they should be set at. FYI: F-250 is 60/60, F-350 is 60/80
Too little psi or too high psi can cause poor steering response or wander. Also, wander occurs when the front end is unloaded due to improper loading or overloading. Finally, being out of alignment can cause wander and towing can amplify the effects. I've had poor quality tires that had poor steering response and braking.
I've not seen a FORD dealer that offers much more than an All Terrain AT tire. Aggressive off road tires would be a special order for a specific off the road need.
Old Oct 17, 2024 | 10:55 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Your truck SHOULD have a screen in the dash that lets you check what pressures your TPMS is reporting - its accuracy can be questionable but it should at least be a rough guess.
One should ALWAYS carry a tire gauge in the glove box. I have one in EVERY vehicle we own. I've stuck with Milton, which is pricier but tend to be more accurate and robust, but even a cheap one from a gas station or dollar store is better than nothing. It's good to check them weekly, at minimum monthly, and ALWAYS before towing.
A good point was brought up above - what's your weight distribution like? Is the weight fairly evenly distributed or is it primarily on the front of the trailer? If it's mostly on the front, there's a good chance you're unloading your front axle too much which will cause handling issues. Given that you're a '17 with 1 yr old tires, it's also possible you need a front end alignment but that depends on maintenance and the roads you travel as to how beat up things get - I've gone YEARS without an alignment on some vehicles (maybe a quick check now and again but no adjustments) while others needed an alignment every year as things wore out and got replaced.
All that said, it very well could be your tires - not all tires are created equal and some just SUCK, period. For instance, the tires that came stock on my FIL's '23 F250 with the Black package seemed to be okay tires, until he crossed a bridge with grating for a surface - he ended up fighting the truck the whole way across. He immediately went to a different tire and hasn't had the issue since.
Old Oct 17, 2024 | 11:01 AM
Hmcfly626's Avatar
Hmcfly626
I guess I'm a idiot yes the air pressure is low but as for the aggressive tire it's agessive to me going from a street tire to this one i have never liked
Old Oct 17, 2024 | 11:03 AM
Hmcfly626's Avatar
Hmcfly626
I guess I'm a idiot yes the air pressure is low but as for the aggressive tire it's agessive to me going from a street tire to this one i have never liked it will go get some more air in it today I had just got my oil changed too it all comes back to me I will take the blame on this thanks all
Old Oct 17, 2024 | 12:47 PM
Hmcfly626's Avatar
Hmcfly626
If you need the traction of an aggressive tread tire to get through mud and muck I am running Centenial MT 12-ply 12.5" width. Slight road noise, but track well and don't spin a lick off the road when I'm pulling my 11.4klbs RV uphill through rain soaked clay fields. I'm running 75psi all around.
The Michelins did most everything exceptionaly well and last a long time, but AT tires load up with mud. If it rained on my land I didn't dare take the RV out on the road.
I had a set of Goodyear Wrangler TrailRunner AT and they pulled better than the Michelin off the road. On road they had some more noise versus the Michelin.
ok I have put air in them all I'm sure this will help the tires a fallen at and like I said I have never likes these from the start Ford put then on without telling me I think it's a big difference between a street tire and a At Tire it has always had a little pull to either side of the road so I'm going to get the Michelin Defender for now thanks all like I said it was my fault not checking the air pressure I'm a idiot for asking for help and bothering all you nice people thanks to all who have commented on my post
Old Oct 13, 2025 | 04:09 PM
CR172's Avatar
CR172
I am really happy with the Nitto Terra Grappler G3's that replaced the OEM POS's at 15K miles. 295/65R20's
Old Oct 13, 2025 | 08:31 PM
  #28
swampster22's Avatar
swampster22
7th Gear
In my decades of driving I would say Michelin- can't go wrong(although my experience is with SUV tires), Large truck tires(35 inch)-Goodyear Duratrac- 20% chance they can't be balanced, Nitto EXO grapplers- excellent, Nitto Recon grapplers - relatively new so wear is unknown, but after a few thousand miles no balance issues or air loss, so positive so far. Falken AT3- no issues. Continental- STAY AWAY. These are my personal experiences, yours may differ.
Old Oct 14, 2025 | 10:15 PM
  #29
rodsev's Avatar
rodsev
Trailering
Michelin Defender LTX M/S2, this is the tire that sets the standard
Old Oct 18, 2025 | 10:50 AM
  #30
Midwest87's Avatar
Midwest87
My Mich ltx were worthless dry street tires only.
Cooper M&S or RT, Kenda At2. Would be my pick. I run agressive Kenda RT's now. Never going back to ungrippy tires for the sake of noise or whatever.
There may be something else wrong with your truck.
