Intermittent gauge cluster
Old Oct 12, 2024 | 10:19 AM
lgerman23's Avatar
lgerman23
1st Gear
The gauge cluster in my 03 6.0 only intermittently works. The lights on the panel work fine it’s just the physical gauges. Sometimes they’ll turn on when I give it a good smack. I don’t believe it is the battery saver relay as I’ve had that issue with the original gauge cluster before I replaced it and it’s not showing any of the symptoms of that other than the gauges not working. I’m struggling to find anything online that doesn’t just say it’s the battery saver relay. I’ve checked the fuse and replaced it just to be sure. Any ideas of what it could be or what I could check?
Old Oct 13, 2024 | 05:59 PM
bpounds's Avatar
bpounds
The gauge cluster in these have a lot of points of failure. I suggest Circuit Board Medics - Automotive, Trucking & Appliance for repair.
Also there are plenty of youtube videos on the topic of these issues. You can search for those and maybe fix it yourself. Or at least learn how to R&R it.
Craig Maffet
Oct 31, 2023 07:49 AM
F150XLT2003v6
1997 - 2003 F150
Dec 28, 2022 08:43 AM
NDF250
Jan 6, 2018 03:50 PM
Hawkmcgee
Aug 24, 2013 09:12 AM
73FOMO
Dec 9, 2010 08:27 AM
