My 2024 F350 does not have a factory-installed rear sway bar and I'll be adding a Hellwig big wig sway bar in anticipation of some future heavy fifth wheel towing. Should I also swap out the front sway bar for a Hellwig big wig as well? Sorry if there are other threads out there about this. I searched, but couldn't find any.
I wouldn't do either. I doubt you'll be able to measure or notice any difference before or after changing/adding sway bars for fifth wheel towing. Might notice a difference with a slide-in camper but not fifth wheel.
Sway bars purpose is to prevent body roll. The fifth wheel hitch should pivot side to side which prevents the fifth wheel from body rolling the truck. If the hitch didn't pivot, no sway bar would keep the fifth wheel from causing body roll...and it would feel very uncomfortable to drive.
Hummm... interesting. So I shouldn't expect to experience sway just from the 14,000 lb. fifth wheel (pin weight about 3,000 lb.)? I am concerned about a harsher ride as well (I've aired down to 55 psi in all four tires and I've replaced the factory shocks with Bilstein 5100s). I don't experience any sway driving unloaded, but I drive kind of like the old man that I now am.
Correct. To elaborate, "Sway" is used a couple different ways in reference to driving/towing. Sway bars on a truck (or car) are about preventing body roll...like when you're going kinda fast around a curve. A fiver does not impart body roll onto a truck. You'll want to take curves slower with the fiver because it will body roll and your truck will have negligible impact on preventing fiver body roll. If you're not experiencing body roll now while empty, then I'd leave it be.
All fiver hitches can pivot from side to side. I've seen one hitch that could be locked to prevent pivoting and believe me you don't want it locked to prevent pivot....the fiver would constantly roll the truck back and forth...you'd feel every uneven spot on the road.
Guessing you're airing down tires only while empty. Definitely air back up to spec when hitched to the fiver.
It is an anti-roll bar often called anti-sway. And there is a huge difference when towing a fifth wheel in the wind. The pivot does nothing. The "pressure point" for a fifth wheel is well above the vehicle's center of gravity. Gusty side-winds put plenty of roll into the truck. You will be glad you added a rear bar. I never upgraded the front bar. It should do the job.
Perhaps it's different with 4wd trucks or anything with a high center of gravity. One of my 3/4 tons has no sway bars, the other has front and rear. I've never felt roll with either while towing the fiver.
I have been in wind strong enough to rock the fiver...even when parked at a gas station. I felt the need to drive slower than normal because of the camper dancing but did not feel truck roll.
Not trying to be ornery, but if you think the pivot does nothing, try wedging it with something to keep it from pivoting and drive a few hundred miles with the camper... then you'll see why the hitch has a pivot.
Adding a sway bar won't hurt anything unless the plan is to do off-roading on very uneven ground. I just highly doubt anyone can differentiate a truck with it vs a truck without it when towing the same fiver.
You have to be careful- too much rear bar and you can set the truck up to understeer. You are better off with the rear end breaking loose than the front end pushing.
I have the factory “Camper Package” rear bar on my CCSB 7.3 F350 and it handles like it’s on rails.
Good shocks like Bilsteins will make a much more noticeable seat of the pants difference.
Sorry, what I meant was that the pivot does nothing to prevent roll in the truck chassis.
I added a rear bar to a previous truck and it made a HUGE different in the wind with a fiver. I 30 mph crosswind in Oklahoma will make that obvious.
It's possible that results vary from truck to truck and camper to camper. For the OP, I wouldn't buy one until I tried it without so I could see if there is a change.
It may be a center of gravity thing with new trucks (especially 4wd) sitting higher than necessary or useful...wouldn't be the first time Ford and other manufacturers messed up a good thing.
They DO sit way too high. Many fifth wheels you see on the road are being towed nose up.
The only time I notice my Hellwig rear sway bar is when I cross speed bumps at an angle. If I cross them straight on, I don't notice the sway bar. I was really impressed with how more controllable the truck was after installation of the bar. Best money I've spent on the truck other than replacing the factory shocks with Bilstein 5100s.
I think your wrong, as too big rear bar will cause oversteer!
