No power
Old Oct 9, 2024 | 09:19 PM
Simondion's Avatar
Simondion
8th Gear
No power
2015 diesel def delete no power. Turbo spools and boost is discharged threw the wgt got that sound of when you step on it and it boosts and you let go right away. Did have that exhaust hiss sometimes use to do it only on cold starts and only first time now it’s all the time
Old Oct 10, 2024 | 03:37 AM
Sport45's Avatar
Sport45
Look for a leak in the charge air system. Hose split or clamp blown off.
Are you blowing a lot of smoke?
Old Oct 10, 2024 | 06:33 AM
Simondion's Avatar
Simondion
8th Gear
No just tiny bit but it was like that before they had it programmed for a bit
Old Oct 10, 2024 | 07:03 AM
senix's Avatar
senix
Inspect your cold side piping, in fact inspect all the related connections to and from the turbo, from the air box and CAC.
Old Oct 10, 2024 | 08:17 AM
Simondion's Avatar
Simondion
8th Gear
I did have a Quick Look didn’t see anything wrong but will take it apart and have a better look
Old Oct 10, 2024 | 08:57 AM
senix's Avatar
senix
should not need to take apart to see an apparent rupture on the hoses,
check it all over, if not found then start the truck and see if you can find it.
Also if the waste gate is coming on a bunch, perhaps it is bad.
I know you have a tuner, but scan for any codes.
Old Oct 10, 2024 | 09:00 AM
Simondion's Avatar
Simondion
8th Gear
No present or stored codes
Old Oct 10, 2024 | 09:06 AM
speakerfritz's Avatar
speakerfritz
do this
senix's Avatar
senix
you could always speak with whoever did your tuning.
Old Oct 10, 2024 | 09:13 AM
Simondion's Avatar
Simondion
8th Gear
Yes I could but the truck has been tuned for the last 4 years I doubt it’s the tune but I will look at the pipes better
Old Oct 10, 2024 | 09:14 AM
Simondion's Avatar
Simondion
8th Gear
Thanks for the help
Old Oct 10, 2024 | 09:25 AM
speakerfritz
Power problems with no codes are usually turbo ductwork as indicated above, or clogged /defective map sensors.
when we say no codes we don’t mean no dash cel’s , we mean no codex using a good odb port reader.
Short of the above the power problem is more likely a defective sensor than an actual mechanical problem.
If I were to guess which sensor aside from the map, I would suspect exhuast back pressure….you can snap shot readings at idle at various rpms to compare to known good ebp numbers .
Old Oct 10, 2024 | 09:32 AM
Simondion's Avatar
Simondion
8th Gear
Yes I got several good devices I got a autel, forscan I will check on readings from a few sensors for sure
Old Oct 10, 2024 | 09:42 AM
speakerfritz
Some numbers at different rpms while parked at this link.
corky numbers at first but good numbers at the end of thread once sensors were replaced.
don’t blindly start replacing sensors with out good data to support it.. gets expensive.https://www.ford-trucks.com/forums/1...ormance-5.html
Old Oct 10, 2024 | 09:54 AM
Simondion's Avatar
Simondion
8th Gear
Thanks for the info
pjretired
6.4L Power Stroke Diesel
Mar 22, 2018 12:27 PM
spocky1187
Jul 3, 2012 12:19 AM
2006powerstroke90
Oct 26, 2011 04:34 AM
96powerstroke
May 10, 2009 07:05 PM
1984 f-250
Apr 20, 2003 10:17 PM
