ECM question
Old Oct 9, 2024 | 12:36 PM
jernigan's Avatar
jernigan
ECM question
I have a 1990 4x4 5.0 with the E40D, I have noticed sometimes lately that on a cold start it does not idle up for the warm up cycle. Could this be a sign that I am having ecm problems? As far as I know it has never been replaced and the truck had sat for 10 years before I got it.
Old Oct 9, 2024 | 01:06 PM
AuroraGirl's Avatar
AuroraGirl
more likely a sign that you have a sticky iac or plugged air filter
Old Oct 9, 2024 | 02:17 PM
jernigan's Avatar
jernigan
I know for sure its not the air filter its new, have to check on the iac. The truck is not being drove right now just move in and out of the shop, slowly doing body work when time allows.
Old Oct 9, 2024 | 03:44 PM
McLeod's Avatar
McLeod
check the resistance values of your engine temp sensor
Thanks to Steve83:
Sensor & Actuator Testing Values
Resistance (Ohms) is measured with the device DISconnected (so the key doesn't need to be ON). Voltage is measured with the circuit complete & key in RUN, as during normal operation. Back-probe the connector, or pierce-probe the wires.
lawdawg79
Oct 19, 2015 09:14 AM
79sparky
Nov 13, 2012 06:03 PM
2005Dually
Dec 31, 2009 11:43 AM
PAVEMENTMAN
41
Sep 10, 2009 09:07 PM
Slider28
Bronco II
Mar 26, 2002 10:04 AM
