Wire gauge recommendations
Old Oct 4, 2024 | 11:53 PM
LarryAt's Avatar
LarryAt
Got a broken black/red wire coming from driver's door front into area leading to behind the instrument panel. Looks like a previous owner tried to splice it there and failed. Gonna trace it from end to end and replace it with tubing around it. What gauge wire is recommended for replacement? I'm thinking 16, but want to verify before I order a 50' spool, which I'm sure I'll need in the coming months of restoration. I'm planning to pull the door panel, and hopefully this wire is coming from one of the fuel tanks and why the gas gauge isn't working. If not, something is gonna get repaired anyway. Thanks.
Old Oct 5, 2024 | 12:15 PM
jflem's Avatar
jflem
16 guage will work but you may consider getting 14 just in case you run across something that needs to carry more amps during your restoration.
Old Oct 6, 2024 | 01:00 PM
knightfire83's Avatar
knightfire83
A quick look at diagrams, found black / red being fed from the fuse box (Fuse #2 14 amp) to the backup light switch then to the backup lights themselves.
Old Oct 6, 2024 | 06:12 PM
Bushbased's Avatar
Bushbased
I have generally erred in favour of taking a wire size larger when replacing wiring, as a vehicle ages so does corrosion at links/connections and especially newer vehicles that have very marginal wire sizing in order to keep costs low.
A prime example is the battery cable sizing now compared to the past, especially as, a say starter motor, ages, it will often draw more current than new, especially with an older battery no longer meeting full voltage spec, the current rises and load on wiring increases leading to burning of starter windings.
Battery wires are something I always upgrade or replace when restoring or servicing older vehicles.
Same for long runs of wire that appear to be deteriorating.
jus sayin' Ross.
davidlgibbs
Jul 6, 2022 01:39 PM
emgee
Mar 31, 2016 06:17 PM
Tyler S
May 10, 2014 08:40 PM
iwanaflattie
19
Dec 3, 2010 06:45 PM
dougDC
Oct 1, 2009 09:19 PM
