Will Ranger parts work?
Old Oct 4, 2024 | 09:43 AM
Dogvila's Avatar
Dogvila
4th Gear
Wanting to do a disk brake swap on my 1970 f-100 but parts are pretty scarce around me. I ran across a 1974 ranger, will those bolt in with the f-100?
Old Oct 4, 2024 | 02:43 PM
tcanthonyii's Avatar
tcanthonyii
This is everything you really need to know.
Installing Disc Brakes on Your 2WD Pickup - Pt. 1 - FORDification.com
I'm assuming you mean F100 or F250 ranger? If so then yes they should be a direct bolt in.
Old Oct 4, 2024 | 11:00 PM
Dogvila's Avatar
Dogvila
4th Gear
From what I’ve read the ranger was just a trim package for the f-100’s in those years? His title just says ranger, asked him if it was an f-100. He also said it didn’t have a proportioning valve on it though
Old Oct 5, 2024 | 10:16 PM
1browski's Avatar
1browski
If the truck has 5 lugs, it should be a f100. Here is a good link on the brake pressure differential valve and the metering valve. https://www.fordification.com/tech/propvalve101.htm.
Old Oct 7, 2024 | 08:40 AM
Dogvila's Avatar
Dogvila
4th Gear
this website is fairly amazing. Thanks.
Old Oct 9, 2024 | 09:17 PM
HIO Silver's Avatar
HIO Silver
If you're not concerned about originality, consider Scarebird Classic Brakes: https://www.scarebird.com/
Use their brackets, add 95-99 Ram rotors and GM truck calipers.
broke77f100
1983 - 2012 Ranger & B-Series
Apr 13, 2006 01:42 PM
Diverduck
Oct 6, 2001 03:04 PM
strawboss
Aug 13, 1999 07:59 PM
