1978 - 1996 Big Bronco
Poor fuel mileage
Old Oct 3, 2024 | 11:19 AM
nutter3's Avatar
nutter3
Poor fuel mileage
My 78 bronco is getting about 7mpg with the 400 /C6 in it. I know it won't get alot better, but it would be nice to be in the 9mpg range. It has an edelbrock 1405 with manual choke that opens fully, MSD aftermarket ignition and distributor, with no vacuum advance.
The exhaust smells really rich. I ordered some new jets and metering rods to try to lean it out.
I measured the base timing, it is about 10-12. But full mechanical advance is less than 30. I bought a MSD mechanical advance adjustment kit, I wil try a different bushing first.
What else can I try to improve this a little? It does runs and starts really well.
Old Oct 3, 2024 | 07:43 PM
cwegga's Avatar
cwegga
You can use vacuum advance... The difference on mine between no vacuum advance and vacuum advance is about the 2 mpg you would like to improve. You should check to make sure your mechanical advance is working correctly too. When mine had a gummy mechanical advance, and a blown vacuum advance canister I got a bit over 5 and with everything working correctly I can brush just above 9 on a good day.
Old Oct 3, 2024 | 08:53 PM
nutter3's Avatar
nutter3
Thanks cwegga. The MSD distributor doesn't have any provision for a vacuum advance. After I lean it and get a little more mechanical advance, I'll repost.
Old Oct 3, 2024 | 09:22 PM
cwegga's Avatar
cwegga
Moving my mechanical advance earlier helped a bit too. It was all in at maybe 3300 rpm and I swapped springs and got it in by 2700 or something.
BrittsNFords
23
May 22, 2016 06:50 PM
mabigredtruck
Jan 25, 2010 01:16 PM
PHetrick
24
Apr 19, 2007 01:05 PM
Dr. Beeker
Mar 26, 2003 07:11 PM
BigF250
13
Nov 30, 2002 06:13 PM
