Water pump testing??
Old Oct 2, 2024 | 03:17 PM
Listor's Avatar
Listor
How do I test that my water pump is working or not , having issue getting heat to come through
l know generally they will leak through the weep hope bits it’s not doing that , I don’t seem to getting hot water lines
Old Oct 2, 2024 | 05:10 PM
helifixer's Avatar
helifixer
water pumps either work or they fail and start leaking, almost never quit pumping.
which lines are not getting hot? if it is the heater hoses you probably have a clogged heater core.
Old Oct 2, 2024 | 05:22 PM
Pikachu's Avatar
Pikachu
Is the cooling system full? Have you felt the lines to and from the heater core to see if they're hot? If the lines are hot, but the air discharge is cool, that usually points to a bad blend door actuator.
Old Oct 4, 2024 | 12:20 PM
Listor's Avatar
Listor
[QUOTE=helifixer;21361234]water pumps either work or they fail and start leaking, almost never quit pumping.
which lines are not getting hot? if it is the heater hoses you probably have a clogged heater core.[/QUOT
i got that resolved, had 2 thermostats from Napa fail , tested them both in a pot of boiling water would not open till 205 , went and grabbed a motor craft thermostat works perfect
Jsapp
1983 - 2012 Ranger & B-Series
Jul 27, 2024 10:37 AM
U.S. NAVY 7.3 F350
Nov 14, 2023 11:51 AM
werewolf-man
Jun 17, 2023 08:51 AM
BRIAN NORCAL
Jul 17, 2017 11:30 AM
fordguy101
General Automotive Discussion
Apr 14, 2005 10:40 PM
