Carter water pump
Old Jul 23, 2024 | 10:56 AM
Jsapp's Avatar
Jsapp
1st Gear
Carter water pump
Has anyone had any experience with Carter water pumps?
Old Jul 25, 2024 | 08:49 PM
trassier's Avatar
trassier
4wd Low
What is your question? I have used Carter water pumps with mixed results. Most have been fine, but I did have one only last a few months before it started leaking - but that can happen with any brand. Most of the water pumps now are made in China. GMB makes a good pump if they have one for your application.
Old Jul 27, 2024 | 10:37 AM
Kruse's Avatar
Kruse
You didn't specify the year Ranger that needs a Carter water pump. So are you wanting to put it on a 1983 Ranger or a 2012 Ranger?
If you want to put the best water pump on your Ranger, buy a genuine Ford water pump with the OEM part number, if you can still source one. And, remember, Ford also sells aftermarket junk that is made in China, Mexico, Brazil or any other source that they can buy it from.
As far as your Carter water pump, odds are it's made in China like just about every other brand out there and they just put their name on it. As noted above, your aftermarket water pump can go 0 to 200,000 miles before you have a failure.
U.S. NAVY 7.3 F350
Nov 14, 2023 11:51 AM
werewolf-man
Jun 17, 2023 08:51 AM
fordflaresides
Apr 21, 2005 09:46 PM
fordguy101
General Automotive Discussion
Apr 14, 2005 10:40 PM
