Customer Satisfaction Program 24B47 - Sync Update.
Old Oct 2, 2024 | 01:41 PM
traveldawg's Avatar
traveldawg
Sounds like this may a solution to my center screen not staying on the views I set each time I start the truck.....
Here is a write up of the program....
https://www.ranger5g.com/forum/attac...47-pdf.217279/
Old Oct 2, 2024 | 06:12 PM
cnote72's Avatar
cnote72
Sounds like this might be a solution to not getting OTA updates too.
Old Oct 3, 2024 | 11:09 AM
kshoop1958's Avatar
kshoop1958
Good thread, following. Sync 4 sure is wonky at times, would be nice if they made it more stable.
Old Oct 3, 2024 | 01:23 PM
senix's Avatar
senix
i am in the listed time frame. never got a letter either. I Printed it
Old Oct 3, 2024 | 02:29 PM
function12's Avatar
function12
My 23 is not in the time frame and sync was just updated at the dealership 2 weeks ago. It still has it's mine of it's own. The smaller section will often start on the nav window. When I always leave it on the media playing. Plus my MyView will not stay what it was last set to either.
Old Oct 3, 2024 | 02:38 PM
acdii's Avatar
acdii
Sync, and MFT both happened to lose last played if a phone was plugged in as the source, even if it is still connected and never disconnected. It is/was due to delays between the boot up and the phone syncing. Hit or miss too, depended on the phone and versions, but just noting that it is nothing new, just surprised it still happens.
Old Oct 4, 2024 | 03:04 PM
7.3TreeFiddy's Avatar
7.3TreeFiddy
The MyView issue has been resolved. You need them to update your IPC module. It fixed mine.
Old Oct 4, 2024 | 03:24 PM
PatrickStapler's Avatar
PatrickStapler
Ditto! Had mine updated about a month ago. No changes at all. My average MPG also shows like 0.3 MPG or 0.7 MPG. So frustrating. However, what I did notice the other day is the average MPG in the small pane on the center screen actually displays what I believe the accurate average MPG. So weird.
Old Oct 4, 2024 | 03:25 PM
PatrickStapler
When they updated my SYNC, they also updated the IPC. Did not fix the issue for my truck.
goodmatt2002
Computer Chips & Tuners
Jun 20, 2012 10:34 PM
DemonRace6
May 17, 2012 07:42 AM
337f250
Jan 26, 2011 10:40 AM
elkarcher
Dec 17, 2005 03:20 PM
