My 23 is not in the time frame and sync was just updated at the dealership 2 weeks ago. It still has it's mine of it's own. The smaller section will often start on the nav window. When I always leave it on the media playing. Plus my MyView will not stay what it was last set to either.
Sync, and MFT both happened to lose last played if a phone was plugged in as the source, even if it is still connected and never disconnected. It is/was due to delays between the boot up and the phone syncing. Hit or miss too, depended on the phone and versions, but just noting that it is nothing new, just surprised it still happens.
The MyView issue has been resolved. You need them to update your IPC module. It fixed mine.
Ditto! Had mine updated about a month ago. No changes at all. My average MPG also shows like 0.3 MPG or 0.7 MPG. So frustrating. However, what I did notice the other day is the average MPG in the small pane on the center screen actually displays what I believe the accurate average MPG. So weird.
