Sponsored by: Real Truck
BCM Programming trouble in Forscan 2014 6.7
Old Oct 2, 2024 | 12:37 PM
Duluthdan's Avatar
Duluthdan
3rd Gear
Hello,
I am trying to load the data I inhaled from the original BCM to forscan and it says it can"t open the file. OK, no problem, I'll compare each line and write each line individually. This mostly works, but some lines say they write the code and then when I re-open the file it hasn't changed. Needless to say the truck is dead in the water. Anyone have any ideas?
Old Oct 2, 2024 | 12:40 PM
Moyni's Avatar
Moyni
2nd Gear
Kinda stupid to ask but is the BCM PN identical?
My 2013 has only done this once, but I programmed a value into the ACM and it spat back out different values that it liked (for adding steering wheel controls). Also might be worth posting to the Forscan forums if you have an extended license.
Old Oct 2, 2024 | 12:47 PM
Duluthdan's Avatar
Duluthdan
3rd Gear
Yes, it is the superceded part ordered from Ford by VIN
Old Oct 2, 2024 | 01:45 PM
ifrythings's Avatar
ifrythings
Loading the “as built data” is only half the job, you still need to program the keys for the PATS system and re-initialize the BCM and PCM (under PATS programming also) to get the truck to start.
Old Oct 7, 2024 | 12:58 PM
Duluthdan's Avatar
Duluthdan
3rd Gear
I have programmed the keys in PATS, reboot the BCM, BCM interconnect, ABS, and IPC and still nothing. Is there anything else?
FishRanger
May 26, 2024 06:51 AM
bronco6767
Feb 7, 2015 02:00 PM
bodabdan
6.7L Power Stroke Diesel
Nov 10, 2013 08:35 PM
Andy's250
16
Apr 21, 2010 09:18 PM
Tat2ed64f100
Nov 11, 2008 11:46 AM
