Replacement C6 transmission pan
Old Oct 2, 2024 | 11:29 AM
art vandolay's Avatar
art vandolay
Anyone know where you can buy a replacement c6 transmission pan for a 78 bronco for not too much money? The old one has a few rust holes that have rotted through from the inside. I bought a stamped steel JBG one for $50 for the owner who doesn't have much money, but it ended up being too shallow for the pickup (pan won't fit). He doesn't have $250 to step up to the cast aluminum finned version.
Old Oct 2, 2024 | 05:26 PM
DB429SCJ's Avatar
DB429SCJ
The C-6 used in 4WD trucks uses a deep oil pan. It also uses a different filter. Check with a local transmission shop in your area. They might have a good used pan. You might be able to change the filter to a 2WD style and use the shallow pan you have. I don't know for sure if you can do that. A good shop can tell you if you can.
Old Oct 2, 2024 | 09:56 PM
JRT812's Avatar
JRT812
I have an oem one if you’re interested. No worries if not..just let me know
Old Oct 4, 2024 | 02:00 AM
art vandolay
PM sent, thanks!
virgojeep
Apr 14, 2010 06:04 PM
BradyCouchman
Apr 25, 2009 11:35 PM
mav4804
Jul 7, 2008 08:24 AM
Timgeorgi
Nov 3, 2006 03:49 PM
epos48
Jan 13, 2005 11:29 PM
