How can the same bulb be used in high and low beam? I would believe that can't possibly be right. I appreciate your answer but if the same wattage bulb is used in high and low beam then all four headlights would be the same brightness.
It was that way for several model years. That’s why Super Duty drivers often had other drivers flash headlights at them. Others would see 4 headlights coming at them and assume they were high beam when in actuality it was 4 low beams.
What's amazing to me is how they doubled the number of bulbs and the output is still absolute garbage. Can't see s*** with these headlights. First thing I did was put Silverstar bulbs in mine, but to be honest I should have gone LED again.
I had 2017, 2019, 2020 and 2022 Super Duties with halogens. I agree with the above statement. I put LED headlight bulbs in every one of my previous trucks. Adjusted properly I was seldom flashed by oncoming drivers. But that's an argument for others to have that I don't get involved in anymore.
At any rate, I finally got a truck with factory LED when I bought the current 2023. I'm much happier with those and with the factory C ring as DRL along with yellow fogs. Nice contrast for others to see me coming.
Everyone is so headlight SPOILED these days!
Boy, my first truck was a 1964 F100, back before there were halogen lights in everything even.
That truck had a 1970 Lincoln 460 and a C6 in it, talk about outrunning the headlights!
As far as my truck, the high beams suck, I hardly ever run them, the low beams do pretty well.
I get headlights flashed at me often, I flash LOTS of people who seem intent on refusing to dim their high beams, I think they are rebelling against all the super bright LED lights in other vehicles.
Each night I am on the road, I get blinded multiple times by some jokers with LED headlights so bright and poorly aimed, that it often is physically painful.
I used to love driving the highways of this country...used to...
Not to mention the jokers with the LED light bars that not only use them on the highway, but refuse to turn them off for oncoming motorists.
