Sponsored by: Auxito
idle problems
Old Nov 30, 2003 | 12:17 PM
Stoner150's Avatar
Stoner150
idle problems
here is a engine problem for you, some one please help.
i have a 1997 f150 with a 4.6 and about 190K miles on it. the problem is, is that when i come to a stop and the truck is idleing it is only at 490- 510 rpms, and sometimes i will stop and it will drop down to 200-300 then jump back up to 500, when it idles at 490-510 it shakes, not terably but it does have a "rithim" to it. also this only happens when the truck has fully heated up, when the temp gauge says anything lower than it's usual running temp. when in park and neutral, and fully heated it's rpms are at about 550.
i thought it was the IAC and so a couple months ago i replaced the IAC and i pretty much solved the problem, the rpms still weren't at 700 but were alot better and never droped down, and just recently i changed the oil and started running it on premium it sarted doing it again.
could running it on premium be causing the problem? should i replace the IAC again? could it be the TPS? or some other problem?
Any kind of help would be greatly appreciated. thank you
Old Nov 30, 2003 | 12:49 PM
Stoner150's Avatar
Stoner150
p.s i looked undernieth my hood, to see if anything looked wrong and i noticed that a couple of my spark plug wires a resting on the head covers, somone told me your wires should not toch any hot part of your engine, could this be it?
Old Nov 30, 2003 | 07:51 PM
LxMan1's Avatar
LxMan1
I would be inclined to agree that it may be the TPS sensor.
I would thoroughly inspect for a vacuum leak first. Check the PCV hose real good, mine went bad at 32,000 miles.
Jimmy
Old Dec 1, 2003 | 09:06 AM
Stoner150's Avatar
Stoner150
well about a year and a half ago i had a major tune up, but i will try the tps sensor, and look at all the hoses. thanks
Old Dec 1, 2003 | 10:28 PM
mars's Avatar
mars
lxman1,
when you say your PCV hose went bad, what exactly do you mean? did it crack, breakdown...?
Old Dec 2, 2003 | 12:41 AM
Stoner150's Avatar
Stoner150
someone said it could be the EGR valve and DPFE no i have no idea what either of these are, could someone please educate me.
Old Dec 2, 2003 | 05:53 AM
LxMan1's Avatar
LxMan1
I believe that it has just deteriorized and got a hole in it back near the throttlebody. The dealer replaced it under warranty so I never really saw it.
Usually if it is the EGR or DPFE sensor, you will get a code for them.
Jimmy
Old Dec 2, 2003 | 06:19 AM
mars's Avatar
mars
at least the EGR and DPFE are easy to get to! just get a good repair manual. you really don't even need a good one, if you're in a pinch a Haynes will do. fifteen bucks and available at any Autozone or Advance Auto! Chilton manuals are more in depth, but they are also a bit harder to comprehend and can be harder to find.
Old Dec 2, 2003 | 11:02 AM
Stoner150's Avatar
Stoner150
i am going to have my friend look at it this weekend when i go racing, he was the one the helped me replace the IAC and has saved me about $500 so far, i will see what he says. what does the EGR and DPFE do? i don't know if i said this before but i had 2 o2 sensors replaced a year and half ago, could the others be going bad? bec when the others went bad, they made the check engine light come on.
Old Dec 2, 2003 | 02:48 PM
Stoner150's Avatar
Stoner150
i went to autozone to find out how much a DPFE was and the guy had never herd of one, what is the true name? and where is it?
Old Dec 2, 2003 | 04:53 PM
mars's Avatar
mars
Differential Pressure Feedback sensor. it's part of the EGR system. pretty likely you'll have to get this from Ford. NAPA doesn't even list it.
you'll find it just to right of the throttle body. it's a 3"X4" silver box w/ an electrical connector and two vacuum hoses attached to it. one of those hoses connects to the EGR valve.
Old Dec 2, 2003 | 06:00 PM
mars's Avatar
mars
Ford calls this the 'Delta Pressure Feedback' sensor.
Marked With O.E.# F4ZZ-9J460B,F48E-BA,BB. Part# 10906. that's from www.tomco-inc.com .
Old Dec 2, 2003 | 06:25 PM
Stoner150's Avatar
Stoner150
thanks, auto zone has a part called EGR VALVE PRESSURE SENSOR, could this be it? it is $53.99
Old Dec 2, 2003 | 09:17 PM
Racerguy's Avatar
Racerguy
Yes that sounds like the right part.
With all the problems that DPFEs are prone to I'd buy a genuine Ford one which has been updated, even if it cost more.
Old Dec 3, 2003 | 12:04 AM
Stoner150's Avatar
Stoner150
does anyone know how much the ford one costs?
