Help with Distributor malfunction
Old Nov 30, 2003 | 08:19 AM
CVokie's Avatar
CVokie
Question Help with Distributor malfunction
I am original owner of 73 F100 4X w/360, manual. Instead of 13.5 degrees for centrifical @2K I have 30 degrees plus, and even faster advance w/vac. So the engine falters before 2000 rpm's, I'm thinking my fly weight springs are bad. Am I on the right track, and if so where can I find new fly weight springs? I looked around yesterday and there are after market springs for GM but i didn't see any for Fords, its the orginal distributor so i'll replace the whoe unit if i have to but would prefer to replace springs if possible.
Old Nov 30, 2003 | 04:00 PM
fordeverpower's Avatar
fordeverpower
i had a pinging problem for my 390 and bought crane cams adjustable vaccum advance kit. I have a ecltronic dizzy . The kit comes with 3 different springs for various mechanical vaccum and the cannister is adjustable as well. I haven't installed anyof the springs but i need to cause i have a lot of mechanical advance as well.
Old Nov 30, 2003 | 04:16 PM
CVokie's Avatar
CVokie
Thanks fordeverpower
Great, I'll look for that kit. Mine will hardly run with the vac attached, w/o it really falters at 2K rpms but is OK just pok'n around. I had some springs I got 20 years ago and never installed, and of course couldn't find them now.
Old Nov 30, 2003 | 04:20 PM
fordeverpower
bought mine from summit for $29.95 but the points ignition is only $22.95. try looking on summitracing.com
Old Dec 1, 2003 | 12:44 PM
Freightrain's Avatar
Freightrain
The springs in these dist. are pretty common pieces. I bet if you bought a set for a GM something, or even for a Mallory they would work in your factory unit. They are all pretty much all the same design and length. The strength of the spring is different, but if you buy a package I'm sure you can find one to use.
It sounds like you have a broken spring and it lets the weight pull the advance up too quick.
Larry
Old Dec 1, 2003 | 04:35 PM
CVokie's Avatar
CVokie
thank you
thats interesting, i'll check that out, that alternative would be the be a good one.
