6R140 Controller
Old Sep 26, 2024 | 11:17 AM
oldguyoldtruck's Avatar
oldguyoldtruck
5th Gear
6R140 Controller
Started my 1979 F250 regular cab restore over three years ago. Almost finished. In December 2022 I was told by a company, they'd have a controller out in early 2023 for the 6R140. So I jumped out and bought a tranny and the adapter plate. Cut the tranny tunnel, fit the transmission welded it all up. But come March 2023, that company didn't respond to emails or phone calls. I put it off for another two months, then finally spoke to a rep. He said "oh no, we're not building that one until maybe late 2024" Well here it is late 2024, and once again no response. I've spent about 35k over the last 3 years and now am going to have to settle on an AOD? I would trash the company, but it won't do any good, as they'll just lie, as I've found out is their preferred method of resolving their BS. They even change their art work flyers to remove the 6R140 references. I wasted about 4 grand on lies. Life will be better soon.
Old Sep 26, 2024 | 11:43 AM
Jetfixer-6's Avatar
Jetfixer-6
Why the 6R140? Hard to see in your photo but it looks like a 460 which can be adapted to a 6R80 which is light years ahead of an AOD. Adapter and controller below.Much more spendy than the AOD however but on par with the 6R140 which is a massive transmission. What are your plans for the T-Case?
https://www.wildhorses4x4.com/ford-6...QaAnrjEALw_wcB
https://www.usshift.com/usq6.shtml
Old Sep 26, 2024 | 12:21 PM
oldguyoldtruck
5th Gear
Cause it's a 2wd 3/4 ton, going to be used to tow a 34' trailer
Old Sep 27, 2024 | 12:36 AM
hivoltj's Avatar
hivoltj
USSHIFT told me their 6R80 controller should control a 6R100 as they are supposedly the same electronically and hydraulically. I don't know if anyone has done it or it would work for your 6R140.
Might chat with them?
Old Sep 27, 2024 | 07:18 AM
oldguyoldtruck
5th Gear
That is not true. I was told that from usshift service tech, Jake (He likes to lie). But when I called and spoke to Kevin, (alleged usshift engineer) he stated that the 6R80 controller will not work with the 6R100.
Old Oct 2, 2024 | 05:17 PM
Jetfixer-6's Avatar
Jetfixer-6
No hope for a controller for your trans. I spent a fair amount of time researching and it's just not happening. If I were to guess, you were either mislead by the adapter plate people or the Quickshift folks. Nevertheless I asked myself what I would do, so here goes...If I were on a budget, I would think with the current administration and rampant inflation you could most likely re-coup the cost of the 6R140 and buy a solid C-6. Newly rebuilt anywhere from $2200--$3500. Then spend another $1200-1500 and get a used gear vendors overdrive which are bulletproof and good for over 1,200 horsepower.
https://www.ebay.com/itm/205014146230?_skw=gear+vendor+overdrive+C-6&itmmeta=01J97M1TKYKB9RB4665D4X5X9S&hash=item2fbb cb9cb6:g:svcAAOSwBeRm9cb0&itmprp=enc%3AAQAJAAAA4Ho V3kP08IDx%2BKZ9MfhVJKlvJB0ugrT6WgEvspePy6TA7X2vrzs n%2FJ4bBu7OwW0c%2BbcEPRU4a65B6tehrTjWxEvwShSWA8sXn p2Bk0HjddtXMN1hhy%2BrIebw****IYJO62zAAEPXQpXQfYrO% 2FN6bB0TVaBp%2FpGw0KFXE%2F32gHczVrXGCznV7Jxdg%2F dAnaC6j3fMewO3cy0ElsLmKrol5DiqsHMwORUp7OvokC72mBfS a%2B788iH%2F6%2FRCdrtfukJoSrhN%2FD0QtpljFn16s24uNe JPBbwD5llYW2Uye4Z9riY%7Ctkp%3ABk9SR4aqh_TJZA
Old Oct 3, 2024 | 07:09 AM
oldguyoldtruck
5th Gear
Just been informed a controller IS going to be available after the first of the year. One of my vendors wanted to have it a SEMA, this year. Either drivable or not, it'll be at SEMA 2025, as a tribute to my nephew.
Old Nov 7, 2024 | 08:21 PM
muddog1123's Avatar
muddog1123
1st Gear
Adapter plate
Where did the get the adapter plate to mount that transmission to the 460? And how much was it want to put one in a 7.3
Old Nov 8, 2024 | 05:50 AM
oldguyoldtruck
5th Gear
6R140
https://transmissionadapters.com/col...r-transmission
The 460 cost me 18k. I sold it to my uncle. That adapter plate system is the best built design I've seen. Very easy to install. You'll have to redue the trans tunnel. My uncles had done it in a weekend.
That's my uncles truck, as I've had to sell mine, since diagnosed with stage 4 lung cancer. Was hoping to see his finished before the end of the year. He's been in talks with US Shift, but I don't trust them.
Old Nov 8, 2024 | 10:22 AM
5851a's Avatar
5851a
Sorry to hear about that.
Old Nov 8, 2024 | 11:27 AM
smoky_diesel's Avatar
smoky_diesel
Dang that sucks about cancer.
A stock 6R80 will handle a built 460 and a 34' trailer just fine. I put 700 ft*lb into the 6R80 behind my 466.
As for a t-case, AA makes and adapter for the 6R80 to 6-bolt round, aka Atlas, 205, ect.
https://www.advanceadapters.com/6r80...RvTLBdKu2Sw1Sn
Erika_
Jun 26, 2021 07:04 AM
x94ray
Mar 3, 2017 11:02 AM
Jeff and Nicolle
19
Oct 31, 2012 11:57 PM
Raff Riff
Jan 3, 2009 11:12 AM
s8whiskey
Apr 17, 2006 11:23 AM
