Brake Question and Troubleshooting
Old Sep 25, 2024 | 05:18 AM
sorrenti's Avatar
sorrenti
Trailering
Just wanted to get some thoughts and opinions as there’s some mixed threads about it.
Recently have went through the brake system on the truck, new wheel cylinders, calipers and lines front to back and replaced a leaky master cylinder as well.
Was having trouble bleeding the brakes and having the pedal return all the way back up, adjusted the link from booster to the master and it started returning faster.
When running now, pedal remains depressed to the floor, tried to unplug the vacuum to the booster and the pedal returns. Just wanted to rule anything else out before buying a new booster!
thoughts? Appreciate it!
Old Sep 25, 2024 | 09:25 AM
mterickson's Avatar
mterickson
Did you bleed the M/C itself? I think you have a lot of air in the line yet. You can bleed the m/c while it's installed, you'll need fittings to screw into the m/c outlet ports that you can connect small hose to them. Run the hose into the m/c reservoir, make sure the lines stay submerged in brake fluid and have someone slowly pump the pedal, when you no longer have bubbles, reconnect brake lines and proceed with bleeding the rest of the system.
You may look into getting a tool to help with brake bleeding too, since I work alone most of the time I grabbed one of these from Amazon.
FOUR UNCLES 2L Vacuum Brake Bleeder - Vacuum Brake Bleeder Kit with 2L Brake Fluid Extractor and 1L Refilling Bottle https://a.co/d/g8lKHMJ
Old Sep 25, 2024 | 10:28 AM
sorrenti's Avatar
sorrenti
Trailering
I bled the brakes from master bench bleed and it seemed like endless bubbles, put it on the truck and bled until no bubbles but the pedal was slow to return until I adjusted the link.
eriksf250
23
Jun 18, 2022 12:03 PM
hulaman
13
Jun 24, 2016 11:24 AM
osufireman
Bronco II
Apr 6, 2010 10:02 PM
91dirtydiesel
56
Jan 23, 2010 06:02 PM
jon1
Bronco II
Jun 25, 2008 01:59 PM
