Lighting issue
Old Sep 24, 2024 | 07:06 PM
Quagst3r's Avatar
Quagst3r
2nd Gear
Lighting issue
Replaced rear leafs and shocked the other day, super heavy duty stuff. Super stiff. Hit a pot hole, lost the dash lights, tail lights, front parking lights. But the headlights are fine. Tried the multi function switch, nothing in position 1, but only headlights in position 2. If I finagle it just right for a little bit, in between positions 1 and 2. Everything works. I am so lost. Took the entire dash apart tested for dc and continuity. Packing it in for the night however so I hope while I’m at work tomorrow someone has some insight. Tried to describe everything as best as I could, though I do suck at electrical troubleshooting. Thanks!
Old Sep 24, 2024 | 09:39 PM
Edgethis's Avatar
Edgethis
Sounds like headlight switch went bad. Seems like you discovered this yourself when troubleshooting. If everything works when the switch is in that sweet spot, then you proved the lights and wiring themselves are fine.
I'd see about picking up a replacement and testing that out.
Old Sep 25, 2024 | 06:02 AM
97-psd's Avatar
97-psd
Agreed. Sounds like the switch is/has failed.
Old Sep 25, 2024 | 06:18 AM
Quagst3r's Avatar
Quagst3r
2nd Gear
see I did that and the same behaviors were present in the old switch and new one, could it really be that probable that the new switch was faulty?
Old Sep 25, 2024 | 07:12 AM
Edgethis's Avatar
Edgethis
Strange, I'd take a close look at the plug for the headlight switch then.
Marciante
Feb 21, 2023 10:33 PM
3624copper
2015 - 2020 F150
Jan 4, 2022 12:50 PM
Bevan1006
Jul 18, 2019 07:59 AM
crazzyt9
Sep 14, 2016 04:31 PM
newjack
Electrical Systems/Wiring
Apr 1, 2005 09:01 PM
