No Crank (solved)
Old Sep 23, 2024 | 03:42 PM
vipersinu2's Avatar
vipersinu2
No Crank (solved)
Hello,
Any Ideas why no crank? I did replace the key switch. That was bad. If I were to wiggle the key. The beeping saying your key was left in the ignition would stop beeping. I took out the PCM and BCM they are dry and crosion free. I cleaned all wiring connectors under both pass and driver kick panels. And under the hood. All the fuses and relays are good. I can hear the gray relay clicking on when the key is turned on. I also hear the BCM relay clicking under passanger kick panel area. I can make starter crank manually by removing relay and jumpering wire to starter but it will not start. I hear the fuel pump for 3 seconds when I turn on key. There is no security light on dash. Battery is new. I am thinking the BCM is bad. Everything works in the truck except for the blower motor. I can also make the blower motor run by removing the relay and jumpering the two wires. Forscan has a bunch of codes. Using forscan I reset all modules and also pushed the as build. Still no luck. Any opinions would help.
===PCM DTC None===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U0100:00-28===
Code: U0100 - Lost Communication With ECM/PCM A
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Accessory Protocol Interface Module
===END APIM DTC U0100:00-28===
===APIM DTC U0151:00-2B===
Code: U0151 - Lost Communication With Restraints Control Module
Status:
- DTC Present at Time of Request
===END APIM DTC U0151:00-2B===
===APIM DTC U0422:00-28===
Code: U0422 - Invalid Data Received From Body Control Module
Status:
===END APIM DTC U0422:00-28===
===APIM DTC U3003:16-28===
Code: U3003 - Battery Voltage
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
===END APIM DTC U3003:16-28===
===BdyCM DTC U0100:00-08===
Status:
Module: Body Control Module
===END BdyCM DTC U0100:00-08===
===BdyCM DTC U3003:16-08===
Status:
===END BdyCM DTC U3003:16-08===
===BdyCM DTC P0230:12-08===
Code: P0230 - Fuel Pump Primary Circuit
- Circuit Short To Battery
Status:
===END BdyCM DTC P0230:12-08===
===BdyCM DTC B10D9:87-08===
Code: B10D9 - PATS Transponder
- Missing Message
Status:
===END BdyCM DTC B10D9:87-08===
===BdyCM DTC U0212:00-08===
Code: U0212 - Lost Communication With Steering Column Control Module
Status:
===END BdyCM DTC U0212:00-08===
===SCCM DTC B11D9:16-08===
Code: B11D9 - Vehicle Battery
Status:
Module: Steering Column Control Module
===END SCCM DTC B11D9:16-08===
===SCCM DTC B1131:08-08===
Code: B1131 - Wiper motor module
- Bus Signal/Message Failures
Status:
===END SCCM DTC B1131:08-08===
===IPC DTC P0460:13-08===
Code: P0460 - Fuel Level Sensor A Circuit
- Circuit Open
Status:
Module: Instrument Panel Control Module
===END IPC DTC P0460:13-08===
===IPC DTC U3003:16-08===
Status:
===END IPC DTC U3003:16-08===
===IPC DTC U0100:00-08===
Status:
===END IPC DTC U0100:00-08===
===IPC DTC U0121:00-0A===
Code: U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module 'A'
Status:
===END IPC DTC U0121:00-0A===
===IPC DTC U0131:00-0A===
Code: U0131 - Lost Communication With Power Steering Control Module 'A'
Status:
===END IPC DTC U0131:00-0A===
===IPC DTC U0140:00-08===
Code: U0140 - Lost Communication With Body Control Module
Status:
===END IPC DTC U0140:00-08===
===IPC DTC U0151:00-0A===
Status:
===END IPC DTC U0151:00-0A===
===IPC DTC U0154:00-0A===
Code: U0154 - Lost Communication with Restraints Occupant Classification System Module 'A'
Status:
===END IPC DTC U0154:00-0A===
===IPC DTC U0401:81-08===
Code: U0401 - Invalid Data Received from ECM/PCM A
- Invalid Serial Data Received
Status:
===END IPC DTC U0401:81-08===
===IPC DTC U0462:82-08===
Code: U0462 - Invalid Data Received From Compass Module
- Alive/Sequence Counter Incorrect/Not Updated
Status:
===END IPC DTC U0462:82-08===
===IPC DTC U0401:00-08===
Status:
===END IPC DTC U0401:00-08===
===FCIM DTC U3003:16-28===
Status:
Module: Front Controls Interface Module
===END FCIM DTC U3003:16-28===
===FCIM DTC U0140:00-28===
Status:
===END FCIM DTC U0140:00-28===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===HVAC DTC B10AF:11-0A===
Code: B10AF - Blower Fan Relay
- Circuit Short To Ground
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC DTC B10AF:11-0A===
===HVAC DTC B10AF:13-08===
- Circuit Open
Status:
===END HVAC DTC B10AF:13-08===
===HVAC DTC B11E5:15-08===
Code: B11E5 - Left HVAC Damper Position Sensor
- Circuit Short To Battery Or Open
Status:
===END HVAC DTC B11E5:15-08===
===HVAC DTC B11E7:15-08===
Code: B11E7 - Air Distribution Damper Position Sensor
Status:
===END HVAC DTC B11E7:15-08===
===HVAC DTC B11F0:15-08===
Code: B11F0 - Air Intake Damper Position Sensor
Status:
===END HVAC DTC B11F0:15-08===
===HVAC DTC B1B71:15-08===
Code: B1B71 - Evaporator Temperature Sensor
Status:
===END HVAC DTC B1B71:15-08===
===HVAC DTC U0140:00-08===
Status:
===END HVAC DTC U0140:00-08===
===HVAC DTC U0401:68-08===
- Event Information
Status:
===END HVAC DTC U0401:68-08===
===HVAC DTC U0401:82-08===
Status:
===END HVAC DTC U0401:82-08===
===ACM DTC U3003:16-28===
Status:
Module: Audio Control Module
===END ACM DTC U3003:16-28===
===ACM DTC U0197:00-24===
Code: U0197 - Lost Communication With Telephone Control Module
Status:
- DTC Maturing - Intermittent at Time of Request
===END ACM DTC U0197:00-24===
===GPSM DTC U3003:16-88===
Status:
- Malfunction Indicator Lamp is On for this DTC
Module: Global Positioning System Module
===END GPSM DTC U3003:16-88===
===GPSM DTC U0422:00-8A===
Status:
===END GPSM DTC U0422:00-8A===
===FDIM DTC B1318-20===
Code: B1318 - The battery voltage level is too low.
Status:
Module: Front Display Interface Module
Diagnostic Trouble Code details
Battery Voltage Too Low
Battery Voltage Low
This DTC may have been set as a result of a discharged vehicle battery or a poor supply connection to the heater unit.
===END FDIM DTC B1318-20===
found the issue, it was the accessory relay in the fusebox under the hood. No DTC and cranks and starts
sequimtwigs
2004 - 2008 F150
Jan 1, 2022 01:45 PM
JerryTaverna
2004 - 2008 F150
13
Mar 31, 2020 12:14 PM
mcerchio
Jan 7, 2020 08:05 PM
SilverSS
1983 - 2012 Ranger & B-Series
Jan 17, 2018 09:00 AM
670johndeere
Apr 16, 2007 07:42 PM
