Anyone recognize this pin?
Old Sep 22, 2024 | 12:15 PM
Phillbo's Avatar
Phillbo
See attached, it's located in the bed next to the 5th wheel plugs and looks aftermarket to me....
Old Sep 22, 2024 | 03:18 PM
BC2019F250's Avatar
BC2019F250
It looks like a slide in camper plug to me.
Old Sep 22, 2024 | 03:23 PM
Phillbo's Avatar
Phillbo
Truck has the factory 5th wheel prep in the bed. Maybe a camper package too? I did not see that in the window sticker.
Truck was registered to a Corporation and the salesman at the stealership mentioned the previous owner used it to tow his Display Trailer. No clue what that means.
Old Sep 22, 2024 | 03:35 PM
T. Banning's Avatar
T. Banning
Use a test light and go thru your lights and see if they’re getting power from those circuits.
Old Sep 22, 2024 | 03:42 PM
Zork's Avatar
Zork
That looks like a weird proprietary thing. Having 5 (!) grooves to line up the plug like that seems very....err....overkill!
Size seems similar to this, but it obviously isn't exactly the same.
Old Sep 22, 2024 | 08:35 PM
edjunior's Avatar
edjunior
If it had the accessory camera/TPMS, it could be the TPMS plug. That's what it looks like anyway.
Old Sep 22, 2024 | 11:27 PM
Kameron Rice's Avatar
Kameron Rice
It’s for trailer brakes, a lot of older horse trailers and boat trailers have these.
its for surge brakes, so the vehicle doesn’t need a trailer brake controller so a 7 way pin ain’t needed. But it requires more power then a 3 way plug for running lights.
goe these surge brakes work is inertia driven. You hit the brakes in your car it pushes on the tongue of the trailer or the gooseneck and apples a piston to actuate the brakes.
still used today, but I think most are converted to a 7 way as that is most available.
its not for a camper, etc.
Old Sep 23, 2024 | 06:01 AM
99powerstrokedF250's Avatar
99powerstrokedF250
That's what I was going to say, looks like an old 5-way round for older surge brake trailers. My boat trailer has a 5-way flat, they gave me an adapter to a 7-way round for it because who has a 5-way flat? The 5-way round...isn't on the way out but isn't used much anymore, as stated above they're usually replaced with a 7-way round because a couple 'dead' pins doesn't hurt anything.
Old Sep 23, 2024 | 10:16 AM
Phillbo's Avatar
Phillbo
Thanks guys.
PlanoRob
Dec 20, 2022 09:55 AM
riltri
Jan 15, 2022 07:05 AM
dagwood57107
Jul 25, 2021 04:11 AM
CPal
All Things Towing
May 20, 2020 11:47 AM
PROxac
Aug 29, 2010 11:28 AM
