GM CP4 settlement
Old Sep 23, 2024 | 12:14 PM
acdii's Avatar
acdii
Originally Posted by rufushusky
Eh, ULSD had been in wide spread use in North America since 2006-2007 and Bosch was 100% aware of the lubricity issue going back to 2003..
http://www.arb.ca.gov/fuels/gasoline...22003bosch.pdf
VE rotary pump (89-93 Cummins) and VP44 pumps (98.5-02 Cummins) also had issues with ULSD and would drop fairly regularly but of course don't super nova the rest of the fuel system when they fail.
That said, Ford won't move on from the CP4 until they are economically incentivized to do so. As of now, the failure rate they are on the hook for requires less cash flow than switching to a standyne (who probably couldn't handle FoMoCo's volume), Denso or anyone else's high pressure fuel system. I do agree the internet greatly amplifies the amount of CP4 failures kicking around out there however the economic magnitude of the failures do tend to send a shiver up the spin of the end user but I agree it is a problem that can be mitigated to a degree. That is of no comfort to those who had a CP4 give up the ghost, who I fully understand their frustrations with the system.
I didn't see the CP4 pump in that study. I think the CP4 came out later, after that report. Bosch made 60 Million of the CP4 in 2 versions though, so it does have a very good track record, just not for US trucks. I also believe Standyne would not be able to build enough pumps for Ford, let alone for the rest of their customers. At least we now have that option.
Old Sep 23, 2024 | 12:49 PM
rufushusky's Avatar
rufushusky
The CP3 was fairly new at the time of that presentation way back in 2003, CP4 was years off. That said ULSD had been around in parts of the world going back to the early nineties, one of the Scandinavian countries Sweden maybe, anyways Bosch should have been well aware of ULSD lubricity deficiencies IMHO of course. I do agree the CP4 isn't the scourge that people make it out to be but the potential boom is a big one. Ok off my soap box.
Old Sep 23, 2024 | 01:25 PM
Prezi68's Avatar
Prezi68
Thoughts on installing a higher volume lift pump?
Old Sep 24, 2024 | 12:16 PM
acdii's Avatar
acdii
You could but then you also have to increase the fuel line diameter. It's not pressure the pump likes, it's volume. You can only push so much volume through the factory lines, at which the pressures go up, so in order for a higher volume pump, you need larger lines for that volume.
wwilson43
2009 - 2014 F150
Apr 9, 2012 05:29 AM
jmikeyj4
Jun 14, 2010 12:07 PM
dkf
Ford vs The Competition
53
Jul 20, 2009 07:33 PM
jimandmandy
Nov 27, 2006 02:10 PM
95250mac
21
Oct 3, 2006 05:42 PM
