Solid Pot
Old Nov 29, 2003 | 04:11 PM
Timken's Avatar
Timken
Solid Pot
Don't know if this has been posted before...are there any bullet casters out there. Time to take a break I loaded up my pot and it went solid on me ,have to wait a little bit (I like to cast at the lowest temp possiable and this will happen sometimes)
Old Nov 29, 2003 | 05:16 PM
Greywolf's Avatar
Greywolf
Nice to know I'm not the only metal melter out there.
We should form up a blacksmith's society, but I bet it's already been done...
Old Nov 29, 2003 | 06:45 PM
Timken's Avatar
Timken
I here you Greywolf, I was back in the shop casting up more .45 bullets. Now I'm sitting here taking another break stuffing a burger in my pie hole.
Old Nov 29, 2003 | 06:52 PM
Vanhecht's Avatar
Vanhecht
my dad is a self reloader as well, along with casting our own bullets...we have ALOT of lead ingots in the garage...
Old Nov 29, 2003 | 06:57 PM
Timken's Avatar
Timken
What kind of alloy do you all use, straight w/weights, mixed w/lino or what?
Old Nov 29, 2003 | 07:12 PM
Vanhecht's Avatar
Vanhecht
uh...we just use straight up lead as far as i know, we try to get rid of the impurities using very high heat...we melt down wheel weights
Old Nov 29, 2003 | 07:29 PM
Timken's Avatar
Timken
Try using some candle wax (sm chunk) and stir it in well ,don't freak when the smoke flames on you it usually does. If you can get a temp probe use it . I cast between 475 and 525 sometimes a little higher depends on the alloy sometimes. If you go too high in temp you can burn up the tin that you need to make hard bullets . Tin will make them hard enough to cut down on leading in the barrel. My metal is a mix of one part linotype to two parts wheel weights, works great. I pick up fired slugs and remelt .
wyomingaggie
19
Aug 18, 2008 10:40 AM
D-ranged2.5
Feb 24, 2005 09:44 PM
fordtrucklover94
Jan 22, 2005 12:58 PM
87rustbucket
21
Oct 23, 2004 12:33 AM
The Fife
16
May 23, 2004 04:48 PM
