Sponsored by: Real Truck
Truck Handling
Old Sep 17, 2024 | 01:17 PM
John McLellan's Avatar
John McLellan
5th Gear
Truck Handling
Hello all
I recently had a rear tire fail that had to be replaced. As these tires had lots of life left in them estimated to be another 15 to 20 K I chose to only change the rear two tires.
Since that time I have experienced a significant swing to the left upon passing a vehicle to the left and also if there is any rapid movement in the steering at slow speeds you get the feeling of being in a tire rut.. The sway if you like is alarming and if you aren't careful could result in loss of control.
So my question could the fact that I only replaced two tires be the cause of this issue. I have had the front end inspected and not defects were found.
The truck is a diesel 2016 F350 Platinum with all the options
Thanks in advance
Old Sep 17, 2024 | 02:07 PM
Ted722's Avatar
Ted722
Welcome to the site. How’d the flat happen? Impact(pothole) or nail/object to the sidewall?
Could be something suspension related front or rear. Did they double check the lug nuts torque too?
Are the replacement tires the same model/size/tread pattern?
Some basic questions, but need more data/context.
Old Sep 17, 2024 | 02:14 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
The other item I will add to the above...
It takes a few hundred miles sometimes for all the oil to leach out and the rubber compound to settle, not to mention all the cords in the tires.
Maybe????
Old Sep 17, 2024 | 03:53 PM
John McLellan
5th Gear
Side wall failure at low speed.
Exact same tire and size same air pressure yes wheel is torqued. Drove a few days on the spare and had no issues
Thanks for your questions
Appreciated
Old Sep 17, 2024 | 03:54 PM
John McLellan
5th Gear
Good point
Old Sep 17, 2024 | 06:11 PM
apache84's Avatar
apache84
What tires might we ask?
Old Sep 17, 2024 | 06:16 PM
John McLellan
5th Gear
Toyo open country AT
Have used them for 4 years with great success
Old Sep 19, 2024 | 09:01 AM
Mike1's Avatar
Mike1
I would rotate the tires, New to the front and old to the rear just to see if the handling is any different.
Old Sep 21, 2024 | 11:30 AM
John McLellan
5th Gear
Thanks for the feedback guys
The response winner is Jimmy's Pilot Service break in period I for the tires as the problem has gone away
Old Sep 21, 2024 | 12:49 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
I'm late to the party but was going to say that ^^ new truck tires are always squirrelly for a few days, even worse when your on the 2 wheeled transportation...
Old Sep 21, 2024 | 05:12 PM
Veteran: Navy
Thanks for the followthrough.....
Tomc750
Apr 20, 2018 04:11 PM
jonrjen
6.7L Power Stroke Diesel
23
Sep 29, 2015 05:50 PM
lidmaker
Aug 21, 2013 05:51 AM
War_is_my_Shepherd
May 16, 2004 10:32 PM
xcopterdoc
Aug 22, 2002 04:17 PM
