Flathead V8 Head Bolt Torque
Old Sep 13, 2024 | 08:21 PM
arthall's Avatar
arthall
Getting ready to finalize the torque on the the head bolts after replacing the head gaskets on a 1953 flathead V8. The manual says 65 to 70 lb-ft. All sources I can find says 50 lb-ft dry torque for a 7/16-14 thread. The bolts have sealant on the threads so they are not dry, but not oiled either. I went to 55 lb-ft and felt like the threads were getting soft. What do you think the head bolt torque should be?
Old Sep 13, 2024 | 08:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The head bolts and the threaded holes in the block were made to a tighter thread spec at the factory, mostly to help with sealing. When in good shape they can take the 65-70 ft-lbs. But if the engine has been apart a couple of times, and especially if the holes in the block have been cleaned out with a tap, they can lose some of that tight fit. For that reason many of the "gurus" on the Ford Barn recommend only going to 55 ft-lbs, and claim success at sealing at that. Worth trying, I'd say. The effect of sealants on the torque values is hard to quantify, but it surely acts as a lubricant to some degree.
Old Sep 13, 2024 | 08:35 PM
arthall's Avatar
arthall
Thanks. Yeah, in my long career as a transmission designer I learned that old cast iron threads really don't have the strength/ductility of new cast. I think I will try 5 lb-ft and see where that gets me.
arthall
Sep 6, 2024 09:45 PM
cookingguy
Nov 29, 2014 10:03 PM
fluidp
Jun 28, 2008 02:56 PM
John - NNY
Flathead V8 & Flathead 6
Apr 26, 2006 08:55 AM
Gooch
1978 - 1996 Big Bronco
Feb 6, 2004 07:36 PM
