239 Flathead Head Bolt Torque
Old Sep 6, 2024 | 05:23 PM
arthall's Avatar
arthall
I am replacing the head gaskets on my 1953 239 flathead. The manual shows the correct sequence for torquing the bolts. Is it recommended to immediately torque the head bolts to 65-70 lb-ft, or should you first torque the bolts to a lower level before repeating the procedure to the final torque?
Old Sep 6, 2024 | 05:38 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
I was taught to torque in steps. I always start with about 40-45 then 50-55, then finish with the required spec.
I also check it again after it's been at working temperature a couple of times, then again at about 100 miles.
This is the way I was taught, your mileage and research may vary.
Old Sep 6, 2024 | 09:45 PM
52 Merc's Avatar
52 Merc
Sneaking up on the final torque in stages allows the clamping force to come down more evenly and reduce the chance of warping things. The block deck on a flat motor is pretty thin and can use all the help to stay straight it can get.
oldskool11
Modular V8 (4.6L, 5.4L)
Apr 13, 2021 07:02 AM
john11139
May 31, 2011 09:40 PM
marilyn
Sep 6, 2006 08:53 PM
John - NNY
Flathead V8 & Flathead 6
Apr 26, 2006 08:55 AM
Gooch
1978 - 1996 Big Bronco
Feb 6, 2004 07:36 PM
