NP435 Fourth Gear Issues
Old Sep 7, 2024 | 08:02 PM
JadenBullNose's Avatar
JadenBullNose
4wd Low
Hey everyone, just finished up my rebuild of my NP435 out of my 80’ Ranger.
Slight issue,
I was pretty careful and precise in the build but now i’m having issues with fourth gear.
Shifting into isn’t the issue but turning by hand results in a problem.
After some spinning, it gets gradually tougher until it “jams”
Reversing it slightly will then allow movement until the issue happens again. (spinning in opposite direction in 4th makes no issues, but opposite direction in 1,2 and3 not allowed?)
All other gears shift and spin fantastic. Any thoughts????
Old Sep 7, 2024 | 08:27 PM
Franklin2's Avatar
Franklin2
All I know is, 4th is not really a "gear". All it does is lock the input shaft to the output shaft. I am not great with manual transmissions, or automatics for that matter.
Where the input shaft engages the output shaft, isn't that where all those little needle rollers live that fall out all over the place when you take the transmission apart?
Old Sep 8, 2024 | 07:36 PM
JadenBullNose
4wd Low
I believe so yeah. I was very precise in doing the build, didn’t rush it at all. Just weird to experience this
Old Sep 9, 2024 | 07:31 PM
Franklin2's Avatar
Franklin2
Thinking about it some more, these modern transmissions have helical gears to make them quiet. But that puts a thrust load on the shafts and pieces in the transmission, so they have all these specs and shims for shaft end play when you are putting it together. Maybe some of that needs to be re-checked. I think I read if the end play is too sloppy, it can cause it to pop out of gear when you goose the engine while in gear. I am thinking maybe having it too tight can cause it to bind up like you are experiencing.
Old Sep 9, 2024 | 09:07 PM
kr98664's Avatar
kr98664
I think I read if the end play is too sloppy, it can cause it to pop out of gear when you goose the engine while in gear…
From my limited experience, the teeth are beveled so as to pull the two shafts together when accelerating. Deceleration pushes them apart. I’m guessing the idea was you don’t want the transmission to jump out of gear when pulling out into traffic.
If your 4-speed jumps out of 3rd when engine braking (or 2nd gear in a 3-speed), the input and output shaft bearings are probably worn and have too much axial play.
Old Sep 10, 2024 | 11:46 AM
JadenBullNose
4wd Low
All bearings are brand new Haha!!!
Rebuild kit came with them!
Old Sep 10, 2024 | 04:58 PM
kr98664's Avatar
kr98664
Laughing right back if you’re convinced a component must be good because it’s new! I do not care to discuss how I learned otherwise.
However, in your situation, I don’t think axial play in the bearings is an issue. If it popped out of gear decelerating in 3rd? Definitely a strong possibility in that situation.
But for binding in 4th gear when turned by hand? I don’t think the bearings are a likely cause. Have you tried turning the input shaft the other direction? Not sure what an improvement there would indicate. Mostly just thinking out loud, piecing the clues together.
Old Sep 10, 2024 | 11:15 PM
JadenBullNose
4wd Low
Silly of me to assume new means good, but wouldn’t bad bearings with axial play affect all gears? 1st through 3rd is as smooth as butter, no issues
I have spun the input shaft in reverse on 4th and that DOESNT cause the same binding. Only in forwards motions which is why i’m confused.
Also in general, haven’t even driven the tranny yet at all. Still on the table being diagnosed and built. This is just the issue after spending time putting it all together
Old Sep 11, 2024 | 03:37 AM
kr98664's Avatar
kr98664
IIRC, the fore/aft movement (due to the bevel gears) is only an issue in 2nd and 3rd. So no, I don’t think a bearing problem is at work here. I blame Dave for leading us down that rabbit trail. We got to talking about other potential problems, but not actually the one at hand.
Do you have the nut (and any spacers) installed on the end of the output shaft? Or is this just a bare transmission? If not fully assembled, I’m wondering if the output shaft is able to walk fore/aft inside the bearing. Still not sure why that only affects 4th gear, but who knows?
Another thought is to remove the top cover and manually move the shift rings. Maybe you could see what’s happening with the shift tower removed.
Old Sep 11, 2024 | 07:43 AM
JadenBullNose
4wd Low
removed.
haha, all good, I do love the questioning, helps get rid of potential problems.
But okay, I have removed the top cover and did shifting by hand. At first, holding back third speed gear would allow for smooth movement in fourth, so that’s where i assumed syncro shimming was the problem (adding more to keep it back)
I cannot see any obvious signs, been holding or pushing on individual components to see what can free up the jamming when in 4th.
Did some inspecting, found small amount of back and forth play with the counter shaft, but no where near enough to move and catch a new gear?
Also, this is a bare transmission on the floor. Only thing hooked up is the tunnel / adapter to my NP208 transfer case (dry gasket on as well). But i like the idea, I could applied in or out pressure on the output to see if it can solve it
Old Sep 11, 2024 | 11:48 AM
FuzzFace2's Avatar
FuzzFace2
The output is a slip shaft like some drive shafts like on my truck and dont remember any output play adjustment?
Only adjustment that I remember is on the input shaft and that is done with different gaskets between the front bearing and the front bearing retainer.
This would adjust the end play for the output shaft too I believe as it is a straight through shaft.
Dave ----
Old Sep 11, 2024 | 05:01 PM
Franklin2's Avatar
Franklin2
Do you have a book or rebuild manual for it? All that back and forth movement you are talking about is supposed to be measured and adjusted in various places. And you do have to assemble and then disassemble the transmission several times to get it right. I am assuming if you are a tranny guy and get good at it, you can make a guess and get it in spec without taking it apart too many times.
Old Sep 11, 2024 | 08:58 PM
JadenBullNose
4wd Low
It’s 100% the 3rd gear / rear syncro ring moving foward. If i apply pressure to keep it back, 4th spins freely without jamming.
Old Sep 11, 2024 | 09:21 PM
JadenBullNose
4wd Low
It’s 100% the rear syncro ring / 3rd gear move forward and put pressure on the syncro rear blocking ring. (In the video i push the gear forward to duplicate what happens when spinning input, hoping it upload)
File Type: mov
Old Sep 11, 2024 | 09:38 PM
kr98664's Avatar
kr98664
I am assuming if you are a tranny guy…
Please let the record show I’m being uncharacteristically good and am refraining from making a cheap joke here, even though it would have been really, really funny.
