Electrical Malfunction
Old Sep 4, 2024 | 11:59 PM
JaredSimmy's Avatar
JaredSimmy
4wd Low
Angry Electrical Malfunction
Hello, I bought a 1995 Ford F-150 4x4 5.0L V8 Eddie Baur and got it up and running enough to bring around town and get to work.
I then figured I'd go get NHTSA 05V388000 (Ford Recall 05S28) handled since I was near the dealer.
They replaced the harness with 8W7Z-14A411-C, but did not replace the switch.
After pulling out of the dealer, the truck stuttered a bit, so I turned around and parked it.
When I went to restart it, it wouldn't turn over and no power appeared in the dash.
I did hear clicking and the brake lights worked fine, but nothing else.
Then, all of a sudden when I opened the door and the chime came on, it sounded odd and out of tune and everything started going berserk.
Several clicks in the dashboard over and over again, all interior lights including the hood light started blinking and flickering, and the "THEFT" and "4x4" Lights flickered on and off with no other dash signals.
I unplugged the battery, had it towed home, and bought a new car for now unsure of what to do next.
Has anyone had this issue or know what might cause this? Where should I look first?
So far, I have checked the fuses, battery, and alternator. All seem to be in order.
All of the cables, wires, and ground appear to be intact.
Thank you for your assistance.
Old Sep 5, 2024 | 04:57 AM
FuzzFace2's Avatar
FuzzFace2
If this happened as you pulled out of the dealer I would have turned around and taken it back.
Even more so when you had it towed home it should have gone to the dealer as something they did was a cause in my book.
Dave ----
Old Sep 5, 2024 | 05:24 AM
manicmechanic007's Avatar
manicmechanic007
Have you removed that harness the dealer put on there with the fuse?
That brake switch can short out and cause trouble
I would re take a look at the battery cables and the fuse links
Maybe your ignition switch is coming apart
Old Sep 9, 2024 | 12:42 AM
JaredSimmy's Avatar
JaredSimmy
4wd Low
I called their service manager and she had it towed back in. Still waiting on any response from them.
Ironww
Oct 18, 2024 01:47 PM
Mountain_anderson
1997 - 2003 F150
Feb 4, 2024 10:21 AM
wsaunders
Dec 22, 2019 04:20 PM
TrenHard
1983 - 2012 Ranger & B-Series
Sep 29, 2019 08:41 PM
Vinford
Jun 22, 2018 10:31 PM
