01 7.3 need help
Old Sep 4, 2024 | 02:14 PM
Christopher2008's Avatar
Christopher2008
1st Gear
01 7.3 need help
I started my truck in the winter let it warm up, left my house started up a hill and as it shifted, a pop sound happend and my ses light came on. Ever since any time I'm around 1200rpm slight vibration at park. No power taking off .In overdrive vibration and no power. No codes come up just the ses light stays on all the time.
Old Sep 4, 2024 | 02:22 PM
udsuth78's Avatar
udsuth78
Is this an automatic or manual transmission? What codes showed when the SES light came on? Do you have a scan tool that is compatible with these trucks? If no then go up to the stickies section and click the Forscan thread. All the info on what's needed and how to use the app is there. It is the best and most affordable option out there for diagnostic tools on these trucks.
Old Sep 4, 2024 | 09:53 PM
kbeefy's Avatar
kbeefy
If the SES light is on, there is a code stored. If you don't see it you need a better code reader.
Get forscan.
Old Sep 13, 2024 | 11:13 AM
udsuth78's Avatar
udsuth78
If the light is on there are codes. Even if the light isn't on there could be codes. You'll need the right scan tool or software and hardware to read them, but they are neither hard to find or expensive. Go read the sticky on Forscan it has all the info you'll need.
Old Sep 13, 2024 | 10:44 PM
JoshHefnerX's Avatar
JoshHefnerX
Did you eyeball under the hood and make sure you didn't blow off a boot?
Mdryden
Oct 14, 2019 01:51 PM
mclarengts
May 20, 2016 02:23 PM
Hansen13
Nov 27, 2015 09:00 AM
PAVEMENTMAN
Sep 28, 2008 09:08 PM
