it SHOULD raise it the 2". Depending on your engine, diesel or gas there might be a little bit of play, however it should be roughly the advertised lift.
is the pro comp leveling kit with an add-a-leave? if so you should consider maybe bds.. they have a 2.5" hanger.. won't give you a hard ride.
