Phone Call Issues
Old Sep 1, 2024 | 12:55 PM
kbrock09's Avatar
kbrock09
4th Gear
Phone Call Issues
I have a 2017 F-150 and over the last week all incoming and outgoing call sounds are being played on the tweeter speakers only. All other Bluetooth sounds are just fine. I have performed a soft reset on the sync system, unpaired and re-paired my phone to the system, and nothing seems to be working. What could be the problem?
Old Sep 2, 2024 | 03:24 AM
RGrew176's Avatar
RGrew176
Not sure what the cause is. You may have to do a master reset and set everything up again.
Old Sep 2, 2024 | 10:03 AM
jake415's Avatar
jake415
Have you tried disconnecting the battery for a few minutes to let any static electricity to bleed off the circuit boards? Is the battery old and weak? Have you had it load tested recently. I think these are the first things to check when chasing electrical gremlins. Good luck.
Old Sep 2, 2024 | 12:16 PM
JKBrad's Avatar
JKBrad
When you disconnect the battery, turn headlight switch on to draw any residual current out of the system. Leave it disconnected for at least 20-30 minutes.
And as @jake415 said, all sorts of weird electrical things begin to happen when a battery is starting to get weak.
Old Sep 4, 2024 | 11:26 AM
kbrock09's Avatar
kbrock09
4th Gear
I disconnected the battery and that did not help.
Old Sep 4, 2024 | 11:46 AM
JKBrad's Avatar
JKBrad
Try a different phone.
Old Sep 4, 2024 | 04:39 PM
jake415's Avatar
jake415
Great. Did you have the battery tested? What is the voltage after it sits a few hours?
Old Sep 5, 2024 | 08:18 AM
kbrock09's Avatar
kbrock09
4th Gear
Battery tested out great.
Old Sep 6, 2024 | 07:49 AM
kbrock09's Avatar
kbrock09
4th Gear
I discovered today that the speaker in each front door isn’t working. I read that Bluetooth voice calls go through the tweeters and the front door speakers. This could be the issue, but is it normal for the speakers in the front doors to go out at the same time?
Old Sep 6, 2024 | 11:18 AM
JKBrad's Avatar
JKBrad
Depends. Do you keep it outside all the time? Do you get a lot of rain where you live? You'll find when you remove the speakers how unremarkable they are. It's a wonder that they last more than 5 years.
Old Oct 15, 2025 | 03:05 AM
Faycoolie's Avatar
Faycoolie
4th Gear
Had this happen in my F-150 too, calls were stuck on the tweeters no matter what I tried. What worked for me was using activecalls on the phone for calls while driving; it routes everything cleanly through the phone, keeps audio clear, and avoids the weird speaker glitch.
Old Oct 15, 2025 | 11:17 AM
GlueGuy's Avatar
GlueGuy
When I use the phone, the sound seems to come from all the speakers. Broken speakers and/or wiring I bet is the glitch.
txdabj1
May 4, 2023 06:25 PM
pdose
Apr 19, 2021 07:17 AM
phydeauxman
Jul 23, 2014 09:25 PM
mikem7
6.7L Power Stroke Diesel
30
Jan 5, 2012 11:03 AM
MannyF150
Nov 29, 2010 02:09 PM
