Sponsored by: Real Truck
lift
Old Jan 8, 2003 | 04:20 PM
Gary E K's Avatar
Gary E K
lift
Old Jan 16, 2003 | 09:05 PM
pkenn7's Avatar
pkenn7
lift
i was just wondering if anyone had or new if i could use a 4 inch lift and 36 inch tires? any rubbing?
Old Jan 16, 2003 | 09:10 PM
DCSpecial's Avatar
DCSpecial
lift
yes, 36" tires would rub a lot with only 4" of lift. Even with 6" you might get a little rubbing, but not to bad. For no rubbing at all, run a 8" lift.
Hope this helps.
Old Jan 16, 2003 | 09:28 PM
PSD_Power's Avatar
PSD_Power
lift
With my lift and tire combo I get very slight rubbing. Dont know about 4" and 36" tires. I was told I could run 37" tires with a 5.5" lift.
Justin
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=9313&.jpg
http://members.lycos.nl/dukesofhazzard/dukeslogo.JPG
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. K&N air filter. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels. pop up gooseneck hitch and firestone airbag spring helpers. Reese fifth wheel hitch for my new toy hauler. Superchips microtuner.
Old Jan 16, 2003 | 09:37 PM
abendx's Avatar
abendx
lift
i think the tire and rim width needed for 36" tires would be the problem. also i'd take the manufactures suggested tire size with a grain of salt.... you might be able to fit their recommended size if you are only doing a blvd cruiser, but not for off road use.
i know all the manufactures say an 8" lift will fit 38" tires with no problems.... but as i had said in another recent post, mine with 11" of lift just BARELY fits the 38" tires in the dirt.
Old Jan 17, 2003 | 06:42 AM
Yeti's Avatar
Yeti
lift
Just because they "fit", doesn't mean they FIT.
These guys are right, it's all about suspension travel.
When you compress the front springs you will most likely tear up some sheet metal.
