2016 5.0 IMRC causing misfire?
Is it possible that the Intake Manifold Runners on a 2016 F150 5.0 could throw a misfire code (P0308) w/o throwing the IMRC Code?
I have checked many data points on this vehicle I can with Forscan and nothing else makes sense.
Also - is there a way to check the fuel rail pressure on this motor via Forscan? I can't seem to find that parameter.
Or is there a Schrader port or something to access to check the fuel pressure?
Any assistance is appreciated!
Thanks,
Tom
Thanks,
Tom
In case you want to know how this troubleshooting process is going - go to the following link:
https://www.f150forum.com/f118/2016-...e-code-563144/
