Clutch pivot bracket for 390
Old Aug 26, 2024 | 11:47 PM
1955Qfc's Avatar
1955Qfc
4wd Low
Hi, I'm looking for the clutch pivot bracket for a 390? Does anyone know where to look? Or have a part #? Thanks
Old Aug 27, 2024 | 04:44 PM
5851a's Avatar
5851a
Is this going in a car or truck? Bellhousing or frame side? Unibody or full frame vehicle. Many choices. Hopefully with a full description of what you are doing someone with parts book can help.
Old Aug 27, 2024 | 05:00 PM
1955Qfc's Avatar
1955Qfc
4wd Low
It's going in a 1977 F150 4x4. I'm looking for that bracket that bolts to the block and holds that side of the clutch linkage
Old Aug 27, 2024 | 06:16 PM
5851a's Avatar
5851a
Hopefully someone can answer now but you may be on your own since no 390's in 77, only 351M and 400's. You might try 76's? Not being disrespectful to you, try the search bar above.
Old Aug 27, 2024 | 07:00 PM
85e150's Avatar
85e150
Factory illustration is linked. Y/M range listed in post.
https://www.ford-trucks.com/forums/1...l#post18387376
Landman 454
Sep 24, 2023 05:07 PM
Brad Brown
Apr 10, 2022 10:11 AM
Johnkimble
Jan 1, 2019 01:19 PM
