Sponsored by: Real Truck
cross over steering (again)
Old Nov 29, 2003 | 01:32 AM
02superstroker's Avatar
02superstroker
Ok, there are so many different opinions on this website about at what height x-over steering is a must. But who is "right"? It seems that there are many guys running 10-12" of lift that don't have any problems, yet many people say anything over 8" of lift x-over steering is a must.
Here is what i am thinking about doing. I have 8" of lift right now, but i want to go to 10 or 10.5. I will do this by using either a superlift 2" hanger or a bds 2.5" hanger for the front. I will be replacing the rear springs.
So, seeing that off-roading isn't an issue. Is X-over steering NEEDED? By the way, please don't just say yes or no.. i am really curious for some reasons as to why.
I want to do this lift set-up by the summer, we will just see about money(i have yet to find that money tree ). In the future i would like to switch out to cross over steering, however i will be at the new height for a while before i can afford that. Remember i am not doing anything soon(unfortunatly) but i just wanted some feedback from you guys who run big lifts or have experience in this.
Thanks a million.
Old Nov 29, 2003 | 05:56 PM
02superstroker
ttt
Old Nov 29, 2003 | 06:37 PM
DCSpecial's Avatar
DCSpecial
I don't have x-over and trac bar relocation on my truck.....yet.
It does reduce the angle of the drag link and the stress on the sector shaft.
FWIW, a couple of guys that I know run x-over on their 8" lifts and it made their steering a lot easier.....they like it a lot.
I've seen quite a few guys with over 8" suspension lifts run w/o it and not have any problems.......also heard of some that have snapped of the sector shaft (I think one guy has broken 2 and working on number 3 right now still with no x-over ). Also, heard of trucks with 4" and 6" lifts breaking the sector shaft.
Just my $.02
Old Nov 30, 2003 | 12:02 AM
02superstroker
what exactly is the sector shaft? The shaft out of the steering gear box?
When x-over is installed, do most of those kits have the trac bar relocations with them to keep the angles the same?
Old Nov 30, 2003 | 09:21 AM
DCSpecial's Avatar
DCSpecial
Yep, where the pitman arm attaches............so when it fails people have no steering.
The x-over setups that I have seen do not include the trac bar relocation........the companies sell the trac bar relocation as a separate "kit".
The only one that I know comes with both is the entire Dynatrac kit.....but that includes a whole bunch of other stuff too.
Hope this helps.
Old Nov 30, 2003 | 11:57 AM
02superstroker
thanks dc.
So really you have to get the seperate trac bar relocation anyways to keep the angles the same right?
Old Nov 30, 2003 | 03:18 PM
DCSpecial's Avatar
DCSpecial
Right.......otherwise you'd most likely experience bumpsteer.
I'd figure that you're gonna spend around $1300 for both x-over steering and trac bar relocation.
Hope this helps.
