Check Engine Light
Old Aug 25, 2024 | 06:43 PM
f250_1996's Avatar
f250_1996
1st Gear
Check Engine Light
My 2021 Ford f250 super duty throwing all these codes: U0074 U02A3 U1013 U029D U0106 U0101 U0307 U02A2 U029E P21CD
including warning lights such as advanced traction control unavailable, hill decent control unavailable, hill assist unavailable, ABS unavailable, and DEF Fault.
Went on about a 5 1/2 road trip was running fine the entire way. As soon as I started my way home all these warning lights flashed and these were the codes when I plugged it in to the OBD. I did read a forum saying to check the back connector near spare tire for moisture so I wiped it down and applied dielectric grease but then it wouldn’t start. I had to clear the codes to get the truck to start and made it home and truck was driving fine (thankfully) as soon as I got home I turned it off and restarted it and they all popped back on ? Any ideas?
Old Aug 25, 2024 | 06:52 PM
jcb804's Avatar
jcb804
Load test the batteries. Diesels are hard on the batteries and they fail sooner. Whatever systems are not getting the appropriate juice at startup are going to set off DTCs, so you get a whole bunch at once like you did.
Old Aug 26, 2024 | 09:01 AM
CBEllis's Avatar
CBEllis
Yes ^^^ this!
Old Aug 26, 2024 | 01:48 PM
senix's Avatar
senix
new batteries. If you decide to test, remove them and bench test.
Old Feb 4, 2025 | 09:14 PM
Wesley Tinnin's Avatar
Wesley Tinnin
1st Gear
did this fix the codes? Is the truck deleted? I’m having same issues on. 23’ with 4,000 miles on it
Jimmy Dean82
6.7L Power Stroke Diesel
May 5, 2021 04:29 PM
SabrinaNicole98
Feb 15, 2018 08:19 PM
DougThePilot
Nov 3, 2011 04:57 PM
blrman1962
May 26, 2007 07:15 AM
BigGreenGiant
Jun 28, 2006 05:27 AM
