E4OD shudder, need help
Old Aug 24, 2024 | 05:41 PM
thompson99344's Avatar
thompson99344
2nd Gear
I have a 1996 F250 4x4 with a 460 cid and E4OD. Truck runs flawlessly but when shifting into OD it has a shudder. Do these trannies have a solenoid that modulates the flow to overdrive to ease the shift of is it something else? Any help would be greatly appreciated.
Old Aug 24, 2024 | 07:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, it does not.
What codes are stored? www.troublecodes.net/ford
Old Aug 26, 2024 | 07:51 PM
aquartlow's Avatar
aquartlow
Many years ago my father had a '90 Bronco with 5.0/E4OD that also had a similar shudder when going into OD, took it to local Ford dealer and they dropped the pan and tightened(retorqued) the valve body bolts-no more shudder. I knew the man running sales counter and the fellow that did the service work way back then, still good friends today. Hope this helps
snydermotive
Feb 26, 2006 06:28 PM
