Ignition Wiring 63 f100
Old Aug 23, 2024 | 02:02 PM
natewalker's Avatar
natewalker
Trailering
Hi, new to this forum. I am currently rewiring a 1963 f100 4x4. Im using a wiring kit from Speedway Motors, which is GM based. I bought a new ignition switch and a pigtail for it but Im having problems figuring out which wire is which on the pigtail. Theres a yellow one, a red and green one, and a red and blue one. Trying to figure out which is bat, ignition, and accessory.
Thanks
Nate
Old Aug 23, 2024 | 03:32 PM
TA455HO's Avatar
TA455HO
Lead Gopher
The yellow wire is the battery wire that supplies power to the switch.
Red/blue is the wire to the starter solenoid.
Red/green is power to the coil via a resistor. This resistor is often eliminated in higher energy non-points systems.
Accessories is the center post terminal on the ignition switch so none of the pigtail wires. Install the pigtail connector on the ignition switch first and then you can use one or more ring terminals on the center post that sticks through the connector.
Old Aug 23, 2024 | 07:36 PM
natewalker's Avatar
natewalker
Trailering
Thank you!
julianrguez
Mar 30, 2023 10:56 AM
soco
Electrical Systems/Wiring
Aug 5, 2012 07:04 AM
faughnbronson
Aug 17, 2011 08:38 PM
ILOVEMY66
Mar 18, 2010 09:21 PM
AWOL
Nov 28, 2002 06:09 AM
