Ford F250 Highboy XLT engine issue
Old Aug 23, 2024 | 12:41 PM
Stens80's Avatar
Stens80
Hi
Got Myself a project and the seller told me the edelbrock 1405 would fit on this car. Feel a bit lost as i have no idea what kind of engine setup i really have😅
Any ideas what needs to be done here? New to the trucks and engine…any tips?
Old Aug 23, 2024 | 03:00 PM
Green72F250's Avatar
Green72F250
You will need a 4 barrel intake manifold for the Edelbrock carburetor to work on that engine. You might be able to find a cast iron 4 barrel intake from a car from this era of vehicles, or get a Edelbrock Aluminum intake manifold for it. Do you know what size engine it is? Is it a 360 or 390 FE engine?
Old Aug 23, 2024 | 03:40 PM
Stens80's Avatar
Stens80
thanks! Is that a fairly easy job? Replacing some gasket pulling out the distributor
if i read the door plate correct its a 360
Old Aug 23, 2024 | 04:46 PM
Stens80's Avatar
Stens80
If I am not wrong tjisnis the part i need then: https://www.edelbrock.com/performer-...fold-2105.html
correct? Anything else to buy except for the gaskets and studs?😅🤭💸💸
Old Aug 23, 2024 | 06:10 PM
GPatrick's Avatar
GPatrick
Before the major surgery involved in an intake swap on an FE that also involves removing rocker arms, etc., you may find that the better short-term path is to install an original-style two-barrel carb or refresh the carb that cam with the truck when you bought it. On a 360 there is not great benefit to a 4-barrel carb unless you also free up the exhaust with headers and duals and even then you may find that the two-barrel is a better match. Since you are new to the truck get it running with a 2-barrel and drive it to learn what else it may or may not need. An intake manifold swap on an FE is not the easiest - especially if you have never done one before not to mention trying to wrestle the 80 pound intake off of the engine. With a 2 barrel you will get less that stellar acceleration and mediocre fuel milage. With a four barrel and no other engine improvements you will have less than stellar acceleration and mediocre fuel economy.
Old Aug 24, 2024 | 02:34 AM
Stens80's Avatar
Stens80
Yeah I agree.
For now I will just get a new carb so I can drive around.
any tips? My old one is a holley i think but I dont know what type😅
Old Aug 24, 2024 | 10:09 AM
1browski's Avatar
1browski
You can get a rebuild kit pretty cheap. They are not hard to rebuild.
Old Aug 24, 2024 | 10:20 AM
Stens80's Avatar
Stens80
can you tell what type carb this is If i decide
to rebuild
Old Aug 24, 2024 | 10:21 AM
GPatrick's Avatar
GPatrick
Start with the numbers shown on the side of the carb in your picture. Get a rebuild kit and go through it. The Autolite carbs that these trucks came with are pretty simple and pretty good but in the reman aftermarket it may be tough to find a good one. Rebuild the Holley and get to know the truck. While you are working on it, pull the distributor cap and do a quick inspection to make sure the mechanical and vacuum advance mechanisms are in good order and check the radial/side-to-side play of the distributor shaft to make sure that there is not excessive wear. If it is still using points, consider a swap to a Pertronix pickup for a more reliable spark.
Old Aug 24, 2024 | 10:27 AM
GPatrick's Avatar
GPatrick
Here is a link at Summit. It says not available but if you contact Holley you may be able to find a rebuild kit. I don't know Autolite 2100's but the tag shows it as a reman so you may be able to use a basic 2100 rebuild kit. Hit google and do some searches. I found some hits on Ebay as well.
https://www.summitracing.com/parts/HLY-64-5337?srsltid=AfmBOoqVCf9OioWVE-YKi43kEDeikijkF1clfQ0QZthIiSP_8aeyqIgV
This shows the Holley part number and cross-references Motorcraft part numbers. You should be able to find a rebuild kit based on the Motorcraft part numbers -
http://www.kakapart.com/parts/holley-645337.html
Old Aug 24, 2024 | 10:32 AM
Stens80's Avatar
Stens80
645337,HOLLEY 64-5337 Carburetor
thanks!
I been searching the wrong Numbers i see😂😂🤭
Old Aug 24, 2024 | 10:35 AM
Stens80's Avatar
Stens80
will do.
looks like the previous owner just cut the line here. This is supposed to be connected to the carb right? Vacuum
Old Aug 24, 2024 | 10:41 AM
Stens80's Avatar
Stens80
This is the truck btw
Old Aug 24, 2024 | 12:01 PM
Green72F250
Nice looking truck! If you decide to do a rebuild on your Motorcraft 2100 carb, Mike's Carburetor has kits and parts for them. He has Youtube videos on how to rebuild them. In regards to your vacuum advance on your distributor, it looks like someone pinched closed the part where your tubing goes? Maybe it's just the angle of the picture?
Mike's Carburetor Parts (carburetor-parts.com)
Old Aug 24, 2024 | 12:15 PM
Green72F250
Here are a couple of rebuild PDF's one of them is from Mike's Carburetor:
2100_manual.pdf (carburetor-parts.com)
Microsoft Word - Autolite 2100 Carburetor Rebuild2.doc (therangerstation.com)
