Headlight Switch Issue
Old Aug 22, 2024 | 02:28 PM
rjlavs's Avatar
rjlavs
I have a cheap aftermarket radio in my 1994 F250 XL, it has Android Auto on it. When I turn the headlights off and push the switch all of the way in, the radio will go to 'night mode', if I pull it out very slightly the radio will go back to 'day mode'. The headlights/running lights don't come on when it's pushed in all the way but its like some circuit is going hot. I have replaced the dash panel bezel with an aftermarket version, could this allow the switch to be pushed in too far? Should I just add a spacer somewhere or does the switch need to be replaced? Has anyone encountered this before?
Old Aug 23, 2024 | 08:46 AM
jas88's Avatar
jas88
Test for power at the back of the radio on the dimmer wire when you press the headlight switch in.
Old Aug 23, 2024 | 11:19 AM
Scndsin's Avatar
Scndsin
Power for the headlights goes through the switch.
They have a record of melting as harnesses age, connections loosen & corrode & grounds get crusty.
Fix all that, replace switch & some of us add remote relays to stop the stress on the switch.
No idea on the replacement panel depth.
Old Dec 4, 2025 | 03:02 PM
adrianpglover's Avatar
adrianpglover
In my case, when I got the truck there were only cut wires where the radio should be, so I couldn't use the harness from crutchfield directly.
scotttahoe
Oct 9, 2013 05:38 PM
dacv01
Jul 8, 2013 08:25 PM
kuzzins27
Feb 13, 2008 09:36 PM
Tuvanhillbilly
Apr 2, 2004 09:27 PM
