Transmission/Truck Lurch at start up
Old Aug 25, 2024 | 06:30 AM
  #31
Addison86's Avatar
Addison86
Originally Posted by bpounds
You can have some tension between the parking pawl and the rear diff out to the brakes. When you parked it, you were in gear (forward or reverse doesn't matter) and you were holding the brake as you shifted to park. That may leave torque on the driveline. When you start it again, the ABS system is holding pressure on the brakes (I'm thinking another nanny safety thing) for about 1 or 2 seconds.
This truck seems to be holding my brakes for me a lot for one reason or another. It isn't a stretch for me to think it is doing it while parked. Maybe your incline sensor thinks you are on a slight angle?
Dude, It’s not the brakes. My truck does it sometimes too, on hills, completely flat ground, etc. And the truck doesn’t hold the brakes when you shift into park, so the weight of the truck will just rest on the parking pawl, not the brakes.
Old Aug 25, 2024 | 08:03 AM
  #32
HorizontalHunter's Avatar
HorizontalHunter
Originally Posted by JayCarver
yes they should. I didnt see the OP state the MY anywhere thou.
Yes it’s a 22 model year purchased in November of 21. It is listed in my signature.
Bob
Old Aug 25, 2024 | 11:18 AM
  #33
FishOnOne's Avatar
FishOnOne
Hey Bob watched your video. Am I the only one that is hearing what sounds like a short 2 click rattle (click.. click) when your truck moves backwards?
Old Aug 25, 2024 | 12:57 PM
  #34
HorizontalHunter
I think that the”click click” you are hearing is me using the key fob to remote start the truck. I’m not sure about the rattle.
Bob
Old Aug 25, 2024 | 03:29 PM
  #35
FishOnOne's Avatar
FishOnOne
Bob
No the click..click I'm referring to is occurring exactly when your truck moves backwards.
Old Aug 25, 2024 | 04:51 PM
  #36
HorizontalHunter
I will have to give it another listen.
Thank you,
Bob
Old Aug 25, 2024 | 08:40 PM
  #37
JayCarver's Avatar
JayCarver
Bob
Gotcha, can’t we sig on mobile.
Old Aug 25, 2024 | 11:41 PM
  #38
SteveSBD's Avatar
SteveSBD
I thought the OP knew that noise was there, it's very obvious(I forgot I have audiophile headphones lol). Yes there is a definite solenoid-sounding noise exactly when the truck moves. I assume it's a solenoid in the trans, or maybe just slack in the driveline (like my Toyota's infamous "driveshaft clunk").
Old Aug 26, 2024 | 03:44 AM
  #39
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You can. Click the 3 lines at the top, go down and hit "View Full Site"
Changes it to the same layout as on a computer...how god intended the internet to be used! LoL
Old Aug 26, 2024 | 04:50 AM
  #40
HorizontalHunter
I had no idea that the noise is there as my ears are shot and I have tinnitus.
If it is a solenoid it would make sense as that’s how hydraulic pressure would be applied to the clutches to move the truck.
Im sure that there is slack in the driveline but in most cases the truck has been sitting for a day or three on a flat driveway so there would be no reason for it to move.
Thanks,
Bob
Old Aug 26, 2024 | 12:29 PM
  #41
acdii's Avatar
acdii
It more than likely is a tight drum that is getting some friction from when the pressure builds up. It might have a leaky check valve that can cause it, dropping pressure when shut off, so fluid drains out of the packs, when starting up the pump energizes the packs with new fluid. My 2018 F-150 did that for a while until the trans was fully broken in. After about 30K miles it no longer did that.
Old Aug 26, 2024 | 11:47 PM
  #42
Vipersgts1's Avatar
Vipersgts1
Unrelated to OP issue I think but wanted to join in the 10spd bashing. I can lightly rev my 23' 7.3 in neutral and it will move a little and make light clunking noises. The lurch foward after putting in park is atrocious sometimes as is putting in D or R after starting. I frequently remote start or wait for rpms to fall. I also use the N trick to ease the pressure on the drivetrain. I actually like the trans most of the time but man it does some weird *****.
Old Feb 13, 2026 | 07:40 AM
  #43
pbauer's Avatar
pbauer
4wd Low
I don't mean to resurrect this old thread, but did anyone ever determine what causes this? My 22 has done it forever. Doesn't seem to have gotten any better or worse - just odd.
gangstakr
Jan 25, 2022 12:18 PM
gangstakr
Jan 23, 2022 07:54 AM
tlt64
Nov 12, 2020 05:13 PM
JumpinJoe
Apr 17, 2009 06:22 PM
