Sponsored by: Auxito
My truck is bouncing
Old Aug 20, 2024 | 07:22 AM
sumbubba's Avatar
sumbubba
1st Gear
I have a 2002 extended cab 4x4 with the 5.4 motor and an automatic transmission 200k miles. When I drive, from about 10-60 mph the front wheels feel like they are square, bouncing, and pulling the steering wheel side to side. There is also a audible roar coming from somewhere. I have a suspicion that the hubs are locked in, but the shaft from the transfer case is not turning, if the hubs were locked that shaft would be turning yes? I checked fuse 23 in the box with two different meters with the switch on run, theres no power to that fuse. Theres no CEL on, can I tell anything with an OBDII reader? Thanks for any help.
Old Aug 20, 2024 | 12:22 PM
RLXXI's Avatar
RLXXI
Sounds like a shifted belt in one of your tires.
Old Aug 20, 2024 | 03:13 PM
Jon Freeman's Avatar
Jon Freeman
Sounds like a bad tire. Have you inspected them for wear patterns?
Capitolmasonry
Jan 26, 2025 11:37 AM
gammatg
Jan 19, 2012 10:40 PM
KCalvin
Nov 1, 2011 06:25 PM
xcnick38
Dec 19, 2008 07:39 AM
darrmann
Nov 13, 2006 07:43 PM
