Tail light Replaccment
Old Aug 19, 2024 | 08:23 PM
jsawyer77's Avatar
jsawyer77
1st Gear
I have a 1973 Ford F100 that my grandfather gave to me and I am starting to work on it. The first thing I need to do is get the tail lights working. I would like to replace the whole housing and sockets as there is a log of corrosion on the old ones and they do not twist out . It has a connector that looks like a block and I can not seem to get it apart. It think these are the original tail lights and this connector is not wanting to come apart no matter how hard I pull . I think it is suppose to come apart like in this picture. any suggestions
Old Aug 19, 2024 | 08:28 PM
tbear853's Avatar
tbear853
'73s had the socket made into the metal reflector / housing, you replace the bulb from the lens side. I forget the year, seems like about '75 they changed to a sealed assembly lense / plastic housing and the socket twist locked in from the back side. As far as I know, you can update to the assembly for later '70s but you'll need correct sockets too.
Your connector is for the whole assembly, brake / tail / backup / ground. If upgraded, they'll change too.
Swank56
13
Mar 2, 2020 05:16 PM
Adam Woolridge
Nov 7, 2015 05:58 PM
Lizzy2003
2009 - 2014 F150
13
Mar 17, 2014 06:53 PM
NewXer
Mar 14, 2014 08:44 AM
Kecky
Dec 8, 2004 05:43 PM
