Aerostar Ford Aerostar
96 aerostar
Old Nov 28, 2003 | 08:01 PM
jdm's Avatar
jdm
96 aerostar
my 1996 aerostar will not come out of park,and the brake lights will not work either.this all started yesteday,i check the fuses under dash,the are all fine.does anybody no if the is a relay somewere eles in the van,or any hints of what could be wrong.
Old Nov 29, 2003 | 02:02 AM
rlmdad's Avatar
rlmdad
jdm,
I don't know of any direct relationship between the stop lights and the transmission shift lever.
I'm sure you have the key in the ignition and turned on when trying to move the shift lever, but your problem may be the lock mechanism associated with the ignition key. If you do not have one, get a repair manual (Chilton's or Haynes) for your model.
As for the brake lights start simple. First check the stop light bulbs to be sure they are ok. Then check the brake light switch attached to the break pedal.
Ron
Old Nov 29, 2003 | 01:32 PM
Berry's Avatar
Berry
I have a 97 and I can't move the shift lever unless the brake pedalis depressed. I guess the brake lights could be tied into this as well.
Old Nov 29, 2003 | 03:52 PM
jdm's Avatar
jdm
thanks for the info,it was the brake light switch,at the brake pedel,on this model if you do not have brake lights you cannot engage the shifter,but it fix now so thanks again.
Old Nov 30, 2003 | 01:33 AM
rlmdad's Avatar
rlmdad
Well, we learn something new everyday. Glad your problem is fixed.
Happy Holiday's
Ron
