Regen issue/Question
Old Aug 13, 2024 | 08:25 PM
turnkyle's Avatar
turnkyle
I have a 2014 F350 with 70k miles on it. This truck is typically only driven on the highway or when towing. I have another vehicle for driving around town. The last couple times I've had it on the highway it will finish a Regen and then within 5-10 minutes of finishing it jumps from 0% full to 20-30% full. Today I drove it out to a friend's house about 20 minutes away up the highway, it regened while driving up there and was at 0%. I hooked up to an empty 7x14 dump trailer, pulled it 15 minutes up the highway to the rock pit, put 1 ton of sand in the trailer and drove 5 minutes to my house and it was at 95% full by the time I got home.
The next day I unhooked the trailer and had to run a couple errands with the truck for the project I was working on and it went into Regen again so I drove up a local state road with a decent climb to put the motor under load for the Regen and it only dropped to 10% complete and then kicked out of Regen and had climbed back up to 25% when I pulled in the driveway. The following day I took the empty dump trailer back to my buddies house and it was up to 45% full when I got back home.
Would this be a symptom of a plugging/failing dpf or a pressure differential sensor? Or? Any ideas on where I can start diagnosing this would be helpful.
Old Aug 14, 2024 | 08:34 AM
senix's Avatar
senix
most likely is it a pressure differential or check the EGT sensors too.
Need to have something that can read live data.
Old Aug 14, 2024 | 11:09 AM
Overkill2's Avatar
Overkill2
That's impressive for a older truck to regen down to 0% but it makes sense because it only has 70k miles and you work it by hauling heavy loads...
I'd look at the DPF pressure sensor(s).. I cannot remember if the 14s got a second sensor but my truck has a pre DPF sensor and post DPF sensor.. go look at the Coffee book PDF in the tech section pinned on top of the forum.
Old Aug 15, 2024 | 10:36 AM
turnkyle's Avatar
turnkyle
I have a scanner that will display a live data stream. What parameters would I need to be looking at?
Old Aug 15, 2024 | 10:41 AM
turnkyle's Avatar
turnkyle
I will have to take a look at that. Thanks for pointing me towards that.
Old Aug 15, 2024 | 11:15 AM
speakerfritz's Avatar
speakerfritz
How old are the map and egr sensors since last replaced.
Old Aug 15, 2024 | 12:42 PM
turnkyle's Avatar
turnkyle
As far as I know they have never been replaced.
Old Aug 15, 2024 | 12:55 PM
senix's Avatar
senix
start with reading all EGT sensors at cold ambient temps and see if you can identify one that is off.
Old Aug 19, 2024 | 02:26 PM
Boaterguy's Avatar
Boaterguy
I was told a dirty/plugged MAP sensor can cause this condition as well, true??
FWIW, my 2015 since new will usually only regen down to about 20-30% depending on driving conditions, and will only go to 10-15% with a static regen, 127K miles later, and still the same.
Old Aug 19, 2024 | 06:21 PM
Overkill2's Avatar
Overkill2
My 16 has 127k miles... when the truck was newer, it would regen lower than it does now, to 10 to 15%. Now i usually see anywhere from 25% to 40%. I climb an expressway with a few pretty long hill climbs when I do regens. Just did a static regen withy iDash, dash at 85%, got down to 10% when it completed. Truck was at 5% the next day but jumped to 10% pretty quick once I started to drive the next day.
Not sure on the MAP sensor though...
Irelands child
All Things Towing
39
Apr 19, 2015 10:32 AM
WALJON
May 2, 2011 01:05 PM
Mante
Mar 2, 2010 05:39 PM
Firefighter 1406
All Things Towing
35
Aug 27, 2008 08:33 PM
