Steering gear box?
Old Aug 13, 2024 | 07:16 AM
wpg_250's Avatar
wpg_250
Steering gear box?
I've confirmed that both will fit my setup and curious if I should buy the newer one with only a few more kms or the slightly older one with a bit less kms and a bit cheaper?
17k kms vs 20k kms is hardly a difference so go with newer or go with less expensive, what you guys think?
https://teamauto.mb.ca/parts/FORD/FORD_F350SD_PICKUP/3559/2020/STEERING_GEAR_RACK/403518/
https://teamauto.mb.ca/parts/FORD/FORD_F350SD_PICKUP/5054/2022/STEERING_GEAR_RACK/533949/
Old Aug 13, 2024 | 07:32 PM
wpg_250's Avatar
wpg_250
@joe blow, what you think my man?
Old Aug 13, 2024 | 08:03 PM
joe blow's Avatar
joe blow
I am not sure brother, I have not messed with my steering box at all.
Old Aug 13, 2024 | 08:19 PM
wpg_250's Avatar
wpg_250
DANG dude, you still running the stock gear box....wow. How many miles on your rig?
Old Aug 13, 2024 | 10:49 PM
Fuzzpuss's Avatar
Fuzzpuss
Seems like a no brainer. Both incredibly low mileage and only one year apart. Why spend more than you have to?
See if they'll throw-in the mounting bolts, FTW.
Old Aug 13, 2024 | 11:23 PM
wpg_250's Avatar
wpg_250
True enough and I believe the bolts I purchased to install my used 2016 gear box will fit either of these units as well and also purchased a Magnafine filter to add to the system when I do the swap 🙂
Old Aug 14, 2024 | 07:55 AM
joe blow's Avatar
joe blow
127k original owner.
Surprisingly I run 37's and have since new. Within the month of owning I had everything purchased and went to my dad's shop and we knocked it out in a day. Perhaps because I run dual bilstein steering stabilizer it helps longevity or to hide the wear.
I am sure it will be time soon but for now it's fine
Old Aug 14, 2024 | 08:15 AM
wpg_250's Avatar
wpg_250
I've run the Rancho dual unit before and I have a brand new dual Bilstein unit just sitting here not doing anything lol and I'm 99% sure the dual units put more strain on the steering box and reduce it's service life. If you were to upgrade to the 6.7 box with overdrive pulley I'm sure you'd see a night/day difference, but why fix something that ain't broke I get that
Old Aug 14, 2024 | 08:41 AM
joe blow's Avatar
joe blow
I have learned to drive the truck with the inadequate powered gear box (pre-turning into spots and in reverse etc etc). Maybe down the road I will upgrade stuff but that is at the bottom of my to do list if ever. I am sure if the truck did not have Toyo M/T 37's it would be a different story.
In dirt and gravel it turns while stationary just fine, but on pavement, stationary and the tires digging in.....not so much
I saw the thread on the 6.7 gear box addition and it was a great add.
I forgot what member here did that to his truck?
Anyone have it handy to link it?
thank you
Old Aug 14, 2024 | 09:07 AM
wpg_250's Avatar
wpg_250
thank you
Quite a few guys have done it here and on org and I even posted up a how to, but can't remember where it's posted lol
gsnscoot
Apr 14, 2023 07:42 PM
Ike3030
1978 - 1996 Big Bronco
Feb 10, 2022 01:28 PM
Jordanangel
Aug 3, 2012 07:39 PM
aeomholt
Apr 20, 2004 04:26 PM
